NEED 83 Ranger 4x4 4cyl sending unit. Please help
Old Jan 6, 2011 | 07:47 PM
g_k50's Avatar
g_k50
sending unit is a resistor, remove the unit, check wire for breaks, repair as needed.
High resistance full, low resistance empty.
Taking it apart and spraying with carb cleaner might be all it needs.
Old Jan 6, 2011 | 08:05 PM
Old93junk's Avatar
Old93junk
Originally Posted by hardwaycooke
could i possibly call you??
or you can call me 419-602-2338
i want to b positive i understand and i promise not to stalk you after.
thanks
dennis
No need, ......standard gage cluster, ALL fuel gages or interchangeable 83-85 years, not sure if same after 86 and EFI.
Any fuel gage sender unit, from a like size tank, 83-85 are interchangeable, after 86 and EFI, they are not.
And Gk50 is correct, all the sender may need is cleaned and inspected.
Any more questions, just fire away.
Old Jan 6, 2011 | 08:08 PM
hardwaycooke's Avatar
hardwaycooke
Originally Posted by Old93junk
83-85 just make sure tank capacity is the same. (Fuel sender unit)
everyone else is telling me i cant use a 84 or 85. and how do i make sure it is the same tank if i'm buying over the phone??
thanks
Old Jan 6, 2011 | 08:18 PM
Old93junk's Avatar
Old93junk
thanks
I thought you were doing the junk yard pulling? Thats the best way to tell you are getting the RIGHT part, too many returns taught me to always pull my own.
As far as I know ALL carbuerated Rangers use the same sender type, just specific to its tank capacity. Standard tank is 15.2 gal, those with a aux. rear tank, it is 11.0 gal.
Old Jan 6, 2011 | 08:33 PM
hardwaycooke
As far as I know ALL carbuerated Rangers use the same sender type, just specific to its tank capacity. Standard tank is 15.2 gal, those with a rear tank, it is 11.0 gal.
did rangers from those years have both size tanks and if so and i am buying from a salvage shop over the phone, is there a way to ask them to check it so i can be sure i am getting the correct one. also, there a tons on ebay for 85 rangers but none say they will fit 83 or 84.
Old Jan 6, 2011 | 08:46 PM
Old93junk's Avatar
Old93junk
Most Rangers only have the 15.2 tank, the 11.0 is a aux rear tank.......Too many people cannot cross reference, and ebay descriptions are FAR from accurate, There are literally no differences in Rangers from 83-85. None that would affect this part.
Old Jan 6, 2011 | 08:52 PM
hardwaycooke
can you look on ebay and see if any of the one for an 85 will fit and let me know. most say fit 85-88 and have 17 gal tanks but a few dont say.
thanks
Old Jan 6, 2011 | 09:04 PM
Old93junk's Avatar
Old93junk
OK, quoting from my 84 Ranger Ford handbook,
15.2 short wheelbase
17.0 long wheelbase except 4x2 with 2.0 and 2.3l engines.
13.0 aux. rear tank 4x4/4x2 long and short wheelbase.
My Chiltons makes NO distinction for fuel sender units from 83-85.
Old Jan 6, 2011 | 09:19 PM
hardwaycooke
so are you saying any sender from any ranger 83-85 will fit, regardless of tank size, location, 4x4 or not, etc???
thanks
Old Jan 6, 2011 | 09:22 PM
hardwaycooke
one more thing..how can the ones on ebay be for 85-88 then??
going to bed. will see ya tomorrow., thanks
Old Jan 6, 2011 | 09:36 PM
Old93junk's Avatar
Old93junk
thanks
As long as it came from the same cap. tank......4x4, v6, 4 banger, means nothing.
Old Jan 6, 2011 | 09:37 PM
Old93junk's Avatar
Old93junk
Because FleaBay is retarded, I have almost quit looking there because of the incompetence encountered.
Old Jan 7, 2011 | 01:08 AM
  #28
michigan66's Avatar
michigan66
I had suggested checking in to LMC Truck for a fuel sender. They do not list a sender for the 83 model . They do list one for the 84 model. A phone call to them will clarify whether they have something that will work for you.
Given the age of your truck, poor electrical connections - corrosion of connectors, bad ground, etc. - could be the cause of your problem. Have you done any checking of connections to see if that will solve your trouble.
Also, another age related problem is the fact that many salvage yards will have shredded any vehicle that old. None of this is very encouraging, I know, but I hope you can come up with a solution somehow or another.
Bat4x4
Feb 5, 2017 10:05 PM
Dogmann
Dec 6, 2011 04:54 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
killer4x4
Mar 9, 2001 06:49 AM
hotrodford_88
Feb 1, 2001 11:38 AM
