DP Tuner Issue
Old Jan 6, 2011 | 01:12 PM
F350kid's Avatar
F350kid
DP Tuner Issue
I just installed my DP Tuner F5 chip, and the truck started, i was letting it idle and get warm in stock tune, and the truck just shut off and now won't start. i am going to take everything apart, and start over, but if anyone knows what could cause this, your answers are appreciated.
thanks,
Sam
Old Jan 6, 2011 | 01:19 PM
PaysonPSD's Avatar
PaysonPSD
thanks,
Sam
Make sure the cable to back of switcher is tight. If it falls off the engine dies.
Old Jan 6, 2011 | 02:12 PM
PwerStroke99's Avatar
PwerStroke99
and tape that chip into the PCM too, that way it doesnt vibrate loose
Old Jan 6, 2011 | 02:43 PM
robs01f250's Avatar
robs01f250
X2...it happened to me
Old Jan 6, 2011 | 05:09 PM
F350kid's Avatar
F350kid
thank you everyone, the truck is up and running, i went back and reinstalled everything from the beginning
Old Jan 6, 2011 | 06:14 PM
big poppa's Avatar
big poppa
What do you think was the problem?? I'm another one that taped the cable in plus drilled a hole thru the PCM cover so the cable wasn't bent awkward.
Old Jan 6, 2011 | 06:51 PM
JOHN2001's Avatar
JOHN2001
I had a similar problem but it didnt die, it would run fine. I could change the tunes but it made no difference in power. I didnt clean the connector with acetone, once i did that it worked great.
Old Jan 6, 2011 | 08:57 PM
F350kid's Avatar
F350kid
well first, the batteries died, so that didn't really help. lol. and then i went back and used ran my finger nail on and between every contact on the PCM and noticed there was some silicone left that i couldnt see. and then taped the chip in nice and tight, and re-installed it, and jumped my truck, and Tah Dah! now it runs beautifully.
