Automatic Transmission Filter Differences
Old Jan 6, 2011 | 06:59 AM
TexasGuy001's Avatar
TexasGuy001
This may have been covered before. My truck has the 4R70W transmission. I recently got a new filter for it. I have noticed that there is a different one listed for the same transmission. Also I think I noticed a typo on Orielly's werbsite. They are calling what I have a 4R75W. I have never heard of that.
Anyway, on to my question. What is the difference between these two filters. My truck takes the FT100. It says that the FT105 is for 4WD. My friend has a 96 2wd with the same drivetrain I have, but he has the 4WD type. Would there be any benefit to changing my pan to one to accept the FT105?
Motorcraft FT100
Motorcraft FT100 - Automatic Transmission Filter Kit | O'Reilly Auto Parts
Motorcraft FT105
Motorcraft FT105 - Automatic Transmission Filter Kit | O'Reilly Auto Parts
Old Jan 6, 2011 | 07:13 AM
lew52's Avatar
lew52
As far as i know , the 4x4 4R70Ws have a deeper pan , so it takes the longer filter , i use a B&M deep pan on my 2wd 4R70W , i use the 4wd filter & the pan has a pin on the bottom that comes up & holds the filter in place , i like the deeper aluminum pans , they never leak , have a drain plug , hold more fluid & have the cooling fins , that with a good trans cooler is a good set up IMO , plus there thick enough to drill & tap to put a temp gauge senser in the side of the pan....Lew
Old Jan 6, 2011 | 07:54 AM
rla2005's Avatar
rla2005
X2 for what Lew said!
Old Jan 6, 2011 | 08:03 AM
TexasGuy001
Thats pretty much what I thought about the filters. Every time I go to the parts store, no matter which one, they try to sell me the one for the 4X4 pan. When I tell them that one won't fit, they often have to pull out the paper book to look at the filters.
That sounds like a good idea about the pan upgrade. I don't know if I will be doing that though.
Thankfully, my truck came with a factory tranny cooler. I have thought about replacing it with a bigger one, but I'll probably leave it until it needs to be replaced or the trans gets rebuilt.
Old Jan 6, 2011 | 08:10 AM
lew52's Avatar
lew52
Yeah , my truck has the factory cooler in it to , the temp never goes over 150 , but i don't tow or haul any heavy loads , also has a shift kit in it that helps....
Old Jan 6, 2011 | 10:29 AM
Jason Lewis's Avatar
Jason Lewis
Motorcraft FT100
Motorcraft FT105
Yep i have the second one, also have a temp sensor in the stock pan tapped on the side lew i am holding around 150 in the summer, it did get high at the hotter parts in the day around 160, Texas 100+ days !
Old Jan 6, 2011 | 12:17 PM
lew52's Avatar
lew52
Ok , 150 seams to be the norm , only gets to 95 most the time in south fl in summer , i have my temp sender the same place as yours....
Alec94F150XL
24
Feb 1, 2026 09:52 PM
annaleigh
Dec 23, 2017 10:03 AM
George84
Oct 12, 2011 10:28 PM
joe f350
Jun 20, 2011 08:06 AM
F250racer
May 7, 2011 12:59 AM
