Springs?
Old Jan 6, 2011 | 06:21 AM
jasonch's Avatar
jasonch
Springs?
Last Friday we were loading the wheelers up on the gooseneck for a ride. I was going to pull it with my truck. It had 2 atvs on it, a ranger, and my rhino. After hooking up and lowering down, my truck was sitting on the ground. Now I know its a '99 and there is some sag in the springs. So my buddy said he would pull it, no problem. He has and '03 7.3 4WD 4 door. didn't even squat his truck, no lift, no extra springs, nothing! Only thing I noticed from walking around was it seems he had and overload spring on top? Anyway just wanted some info, may have to look into a small lift to get her back up where she needs to be. Thanks in advance!
Old Jan 6, 2011 | 08:37 AM
joeyd61's Avatar
joeyd61
Jason,
I don't have any information for you but i do have a good set of stock springs off my 2003..don't even know if they will fit or how to get them to you...they are here if you need or can use them
Old Jan 6, 2011 | 08:52 AM
robs01f250's Avatar
robs01f250
I could understand your truck squatting if you were using a bumper pull trailer, but for it to squat that much pulling a gooseneck just doesnt seem right. I have pulled 2 jeeps with lift kits and didn't squat at all
Old Jan 6, 2011 | 09:59 AM
jasonch's Avatar
jasonch
I was wondering what the difference was. Not sure if the 03 springs would fit or not.
Old Jan 6, 2011 | 11:40 AM
Mike F250's Avatar
Mike F250
do you have any broken leafs in the pack? They can be hard to spot some times
Old Jan 6, 2011 | 11:43 AM
PaysonPSD's Avatar
PaysonPSD
I have a '99 with the overload springs and even with a 5th wheel hooked up it would only contact the overload springs if I hit a bump or dip. I did have the 4" blocks at that time (E99). You need some new springs. The '03 springs will fit.
Old Jan 6, 2011 | 12:59 PM
lanidan's Avatar
lanidan
My '00 has a similar spring issue. Put a load of concrete in and it squats a bunch. My brother-in-law puts the same load in his '00 Dodge 2500 and hardly any squat at all. Then I get to listen to him run his mouth. Any ideas on price for a new set of rear springs?
Old Jan 6, 2011 | 02:04 PM
jasonch's Avatar
jasonch
i may have a broken spring, but the truck sits level. the bed is a little off though, just figured it was were the previous owner put the hitch in and did not put a washer back where it needs to be or something.
