OBD Code Reader recommendation
Old Jan 5, 2011 | 11:57 PM
wpnaes's Avatar
wpnaes
I hear lots of users talking about codes. What do you recommend to use as a code reader, then how does one find the decoder ring? Do I have obd1 or 2 in my 2000 V10?
Searching past posts, I found these:
https://www.ford-trucks.com/forums/8.../dp/B000KGCUMA
Actron Autoscanner
U581 CAN OBDII/EOBDII Memo Scanner(live data).
https://www.ford-trucks.com/forums/1...373%26sr%3D1-1
Autoengenuity
Actron OBD11 autoscanner
Snap-On 2500
Creader OBDII code reader
Autoxray 5000
I'm getting lost in options. thanks.
Old Jan 6, 2011 | 12:10 AM
jh818's Avatar
jh818
You have OBD2.
I have the Actron handheld that gives only the code. I also have a Scangauge2 that could give more detailed info.
Old Jan 6, 2011 | 02:14 AM
Stewart_H's Avatar
Stewart_H
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle
My choice of scan tool.
Stewart
Old Jan 6, 2011 | 06:22 AM
tdappleman's Avatar
tdappleman
Stewart - it shows bi-directional capability in the list of specs. Can it open the ABS valves for bleeding? I've been looking at the Snap On Modis tool for my shop but just can't get my head wrapped around the 4000 + quarterly updates....
Old Jan 6, 2011 | 09:57 AM
howler4x4's Avatar
howler4x4
Depending on how deep you want to go...
If you want a 'lite' code reader at reasonable cost get the Scan Gauge II.
Con: Won't read tranny codes, maybe more. Not bi-directional, won't open ABS valves.
Pro: Digital tranny temp gauge on the dash, about $160
Old Jan 6, 2011 | 11:30 AM
wallz's Avatar
wallz
I also have the AE software scanner. And yes it has all the abs functions. Deals with pats programming, O2 sensors, and can record while taking test spins. Basically covers all sensors available to be read, and breaks them up into 4-5 sections.
Old Jan 10, 2011 | 10:06 AM
desertt5's Avatar
desertt5
AE is my recommendation also. Used to read transmission line pressures a while back to troubleshoot a trans problem. It does more than I know how to use still.
A definate must for those with a diesel, but will read codes plus tons more for your V10, as already stated.
Old Jan 10, 2011 | 04:37 PM
Stewart_H's Avatar
Stewart_H
Aint that the truth!
Just not enough time to go out and play with it.
Stewart
Old Jan 11, 2011 | 05:16 PM
radmacks's Avatar
radmacks
Just my two cents, purchased a $20.00 including shipping bluetooth one from fleabay. Works with my windows mobile 6.5 phone, my android phone and my win 7 laptop. I have a pile of software and can test / check just about everything I could think off from any of three devices.
Now if I can just get my hands on some ecc reflash software
carchub
May 6, 2013 06:28 PM
fastlad1990
1997 - 2003 F150
Jul 23, 2010 09:21 AM
thordehr
May 14, 2010 04:25 PM
KT987
Dec 11, 2009 12:01 PM
problemchildsmom
Mar 10, 2009 11:45 AM
