AC Compressor Clutch Isn't Spining
Old Jan 5, 2011 | 06:31 PM
big poppa's Avatar
big poppa
Hello guys and gals, happy holidays to you all and your families. Just some things I've noticed in the past couple days, #1 AC compressor isn't engaging or disingaging. The clutch turns freely but looks like the clutch assembly is a bit closer in, not popped out like it used to be, or I think it should be. My heat works fine but if I remember correctly, it still used to cycle. It was cold this morning and I tried the AC and defrost and the compressor didn't turn on. Is this because its cold out it didn't cycle?? My defrost works, I used it last nite and it cleared the windows but I'm not seeing that clutch cycling like it used too. Question, does it cycle less during the winter months?? Any help is appreciated.
Old Jan 5, 2011 | 09:16 PM
DieselCamper01's Avatar
DieselCamper01
I don't have a positive answer on your questions Mike but I wonder if the air gap is too big?
Old Jan 6, 2011 | 05:04 PM
big poppa's Avatar
big poppa
I don't know Jay and thanks for the response. I pulled the number #10 fuse out of the panel for the clutch and it was OK. I'll just keep an eye on it, its too cold to do anything now unless it blows up.
Old Jan 6, 2011 | 05:21 PM
spdmpo's Avatar
spdmpo
Im not sure Mike, I'll see if mine does it in the morning. I want to say in extreme cold it won't cycle.
Old Jan 6, 2011 | 05:33 PM
Speedjester's Avatar
Speedjester
Easy way to test the compressor is to wire a razor blade to a length of wire...attach the wire to the positive of the battery... Then use the edge of the razor blade to probe the connector of the compressor if the compressor clutch is good it should engage once you energize it...
If the clutch doesn't engage the clutch is toast... If it does engage I would then check the low pressure switch... Or borrow a set of gauges... As the system will not cycle if refrigerant is low...
Also if you were low in the summer when temp was high in the cold weather pressure in system will drop to the point the low pressure switch will not energize the clutch
Good luck
Old Jan 6, 2011 | 05:36 PM
big poppa's Avatar
big poppa
I hope so brother, never noticed the clutch not clicking on sporadicly. I did some searching, love that feature but just wanted some input as if anybody elses does the same thing during these cold months. I know Pop and a few others here have info on checking the air gap like Jay mentioned but wanted to rule out any other little things before digging in. Its not siezed so thats a good thing.
Old Jan 6, 2011 | 05:45 PM
big poppa's Avatar
big poppa
Good luck
I will give this a shot tomorrow morning, thanks for the info.
Old Jan 6, 2011 | 06:03 PM
PwerStroke99's Avatar
PwerStroke99
Mike, mess with that electrical connector on the High pressure side and see if it will engage. I had the same problem this summer, and replaced it with a new connector and pigtail, fixed my problem.
Old Jan 6, 2011 | 06:19 PM
bcaughhorn's Avatar
bcaughhorn
x2 on the gauges. check the freon level.if its good you can bypass both switches high and low(one at a time) to see if one is bad
big poppa's Avatar
big poppa
Will do Ken, I faintly remember someone mentioning that, thanks again.. bcaughhorn, I checked the freon level during this past summer and the levels were fine, high side anyway, not sure on the low side. I checked with a rinky dink freon tester, problably should get a set of those good gauges, thank you also..
Old Jan 6, 2011 | 10:01 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Mike if you dont have and feeler guages to check the air gap, start the truck, turn the ac to max, fan on high and bump the clutch plate with a hammer handle and see if it engages. Or withthe truck shut off, unplug the wires on the compressor and just hook a jumper wire up from you battery terminals to the terminals on the clutch compressor and see if it engages.
Old Jan 8, 2011 | 09:23 AM
big poppa's Avatar
big poppa
I just checked it this morning. Ran a wire from the positive side battery to that connector, its not engaging at all, I think my compressor is shot. I'll take a closer look at it this weekend Sun and see where I'm at. I'm bummed, really bummed but my truck has been wonderfull since I bought it and I can't complain, just glad it didn't grenade or something..
Old Jan 8, 2011 | 11:24 AM
bcaughhorn's Avatar
bcaughhorn
sounds like a compressor to me.
Old Jan 8, 2011 | 11:46 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
You can just get the clutch and they arent too expensive. Easy job just one bolt in the center of the clutch, then slip it off and slowly slide the clutch off. You can use a screwdriver on each side and slowly work it off being careful not to damage the compressor.
oops forgot ther might be a big snapring holding the clutch in.
Old Jan 8, 2011 | 11:59 AM
bcaughhorn's Avatar
bcaughhorn
i would check the pressure on both high and low sides before buying anything. if theres a broke valve inside the compressor a clutch will not help. but the clutch is easy and cheaper if thats all you need
