Timing Questions
Old Mar 6, 2003 | 01:47 AM
Chtulu473's Avatar
Chtulu473
Question Timing Questions
I would like to bump up the timing in my truck to 10-12 degrees. How would I go about doing this without a timing light or anything like that? Is that possible? And what should I expect after doing so? Also, how much would an MSD ignition help my truck? Is it worth the money? And while I'm on the electronics, while searching through FTE, I found a link to the Superchips website, and found a chip for the 300. They advertised +14hp and +35lb/ft. Has anyone tried this chip out? If so, does it really work?
Old Mar 8, 2003 | 02:35 PM
super_ranger's Avatar
super_ranger
Timing Questions
you prolly cant get it exact but loosen up the clamp on the distributor and turn it slightly, i forgot which direction cause i dont have my haynes manual and dont feel like going out in the blizzard now to look at the cap
Old Mar 8, 2003 | 08:24 PM
Shepard's Avatar
Shepard
Timing Questions
I advanced mine a little using the method described above. Worked great. I did not go very far as I was told by a friend to be concerned about increasing temp and burning.
