door removal
Old Jan 5, 2011 | 10:40 AM
52 M1 Kootenay Kid's Avatar
52 M1 Kootenay Kid
door removal
I chose to seperate the door hinge from the door jam.
I used a Greenlee 3/4 UniBit.
I had excellent results.The Phillips screw hole worked as a center for starting.The flare on the way up the unibit matched the countersink taper fairly well.
Greenlee has fairly good steel and did all the screws like butter.A gentle screwdriver pry was all that was needed to pop the last thin thread of screw steel free.
