Standard Clutch & Brake Pedals
Old 01-04-2011, 07:50 PM
fastford5913's Avatar
fastford5913
fastford5913 is offline
Question Standard Clutch & Brake Pedals
Can anyone tell me what year model clutch and brake pedal sets will fit my 59' custom cab? It now has a brake pedal for an auto tranny , but I want to change to a top loader four speed... Thanks for the help...
Old 01-05-2011, 12:32 AM
kenjh's Avatar
kenjh
kenjh is offline
my books show 57 to 60 use hydraulic setup's.if your converting..you can use the newer style or cable type so ..low buck ..an' salvage yard part's or new form speedway ??what do you want??easy install or trick new stuff??....sorry not much of an answer but ..someone had to get this going....and by the way ,,,welcome to the nut house!!do you have pictures of your truck???
Old 01-05-2011, 05:30 AM
fastford5913
trick new stuff would be ok i guess.So what do I need? and yes I have a small gallery... thank you!!!!!!!!!
Old 01-05-2011, 08:40 AM
kenjh's Avatar
kenjh
kenjh is offline
first ,what is your budget?what are your abilitys.what do you want in the end?easy way .hit the wreckers and find a stock brake and clutch set up pull it out yourself so you get all the bolts and see how it fit and how it is differant from your truck..if you want a trick setup..well what motor are you running?check out the sponsers here and you can find anything you can imangine...my projects change as money or interest changes..so I am not a good referance..I am into simple ...and make do with what I have....but I have 40 years of collecting crap.....OH bye the way ..good morning..
Old 01-05-2011, 08:44 AM
kenjh's Avatar
kenjh
kenjh is offline
just looked at your gallery..wow ..very nice..now I feel like a twit...
Old 01-05-2011, 10:54 AM
fastford5913
my motor is a 600 hp 400M block with clevland heads so I need to know what bellhousings fit and what my options are for standard shift trannys.Will most years of clutch pedals fit etc...Don't feel kike a twit cause that truck didn't get like that overnight,I think its been torn down for about ten years and I still ain't done... Thanks in advance for your help!!!!!!
Old 01-05-2011, 11:28 AM
ibuzzard's Avatar
ibuzzard
ibuzzard is online now
Panties NOT in a Twist
Roger,as far as a stock installation,57-60 should be the same.Since you're putting in a different combo engine/tranny,I can't say what will work in your 59.Surely someone here will be able to answer your question,though.I will contact another member,Mr4speedford,who has our era of truck,and ask him to read/respond in this thread.You can't begin PMing, or emailing individual members till you've had 25 posts, I believe.
Steve
