strange noise durring accelerating
Old Jun 21, 2012 | 04:50 PM
awq134's Avatar
awq134
if your issue is indeed the same as mine i don't see how the muffler is the problem, but i hope for your sake it does fix it. The only reason i say this is if it were the exhaust, why wouldn't it do it at any speed when your eng. was at the same approx. RPM with the same exhaust airflow. Just my thought process.
Old Jun 21, 2012 | 11:11 PM
rjmogs06's Avatar
rjmogs06
I have a 2012 5.0 XLT and have noticed a similar noise from mine, the first I heard it was the night i drove it away from the lot. Now has about 700 miles on it and is still making the noise, thought maybe it was something to do with break in. Seems to do it at mid speed 45+ mph shifting into passing gear pulling an incline nothing to severe around 2000 rpm. Seems to be from the front of the truck from both sides.
Old Jun 22, 2012 | 06:36 AM
meborder's Avatar
meborder
i know it's been brought up and dismissed ... but all of these sound like preignition.
anytime someone says "rocks in the engine" or "can full of screws" ... that's pinging.
be aware that the gasoline distributors here in south dakota were about to get sewed by the state for mislabling the pumps. they were selling 85 octane fuel and labling it 87.
just something to take note.
if you got a truck that makes these kinds of sounds, particularly at low rpm and high load, it could be spark knock (pinging), and if it is persistant a high octane fuel should make it stop. if it does, then you need to figure out if you are just getting crappy gas, or if there is something wrong with the truck. it *should* adjust the timing below the preignition threshold, and if it is not doing so, it is either because it cannot retard the timing any further (crappy fuel), or there is something wrong.
my 2010 just did this when i filled up with regular fuel for the first time in about 8000 miles. i usually use e30 or e85, and when i switched to our regular fuel (e10 i presume) the truck did ping for a little bit, until it relearned the timing curve for that fuel.
that's what i'm thinking.....
Old Jun 22, 2012 | 04:20 PM
awq134's Avatar
awq134
as in dieseling where it is igniting the fuel without a spark?
Old Jun 22, 2012 | 11:13 PM
meborder's Avatar
meborder
same idea, slightly different in application though.
for a good read:
Engine Basics: Detonation and Pre-Ignition by Allen W. Cline
keep in mind that these engines have a very high static compression, high enough that in years past they would have required premium fuel. current engine and computer technology allows the computer to adjust the cam and ignition timing to allow the the use of lower octane fuel *87 min*
the only problem with that is that when anything goes wrong, the engine may not be able to adjust the timing fast enough or far enough to keep the engine out of detonation (or pre-ignition).
it's just a theory, but it is not hard to immagine that if they were selling 85octane swill here and labling it as 87, that they could be doing it elsewhere as well.
Old Jun 23, 2012 | 06:44 AM
awq134's Avatar
awq134
thanks for that article, that was a good read.
Old Jun 25, 2012 | 04:24 PM
mikfitz's Avatar
mikfitz
hi
hi guys ive got a 2011 platnium,5.0 motor that was doing what you guys are talking about, my motor would ping and knock going up hills under load hard acceleration and such ,change fuel no luck the funny thing is it would happen so ramdomly so took it to dealer they heard said it said it wasnt normal and to drop it off three days later the rep calls and said it was an intermitantly failing fuel pump. that would explain the randomness of the issue ,changed fuel pump no more issue hope it helps
Old Jun 28, 2012 | 04:28 PM
badfl97's Avatar
badfl97
i had this problem with 04 it was a iwe actuator for the 4x4 try putting it in 4x4 when it happens if it stops thats a good place to start easy to do cost like $25.00 hopefully its not your iwe's.
Old Jun 28, 2012 | 11:18 PM
rjmogs06's Avatar
rjmogs06
Well the new F150 (1200 miles) is off to the dealership this weekend, I'll update with what they find. I'm still not 100% sure that what i'm experiencing is the motor pinging, but who knows I've been wrong before.
Old Sep 14, 2012 | 01:27 PM
No.Va.F150's Avatar
No.Va.F150
did any one ever solve this issue? i have the same noise coming from my front end (2011 5.0 scab 4X4).
Old Sep 14, 2012 | 04:53 PM
rjmogs06's Avatar
rjmogs06
Yes the dealer actually was able to fix my issue, although it took atleast a couple of their mechanics a good day to find it. They found that one of the "T" fittings on a vacuum line for the hubs was broken.
Old Sep 15, 2012 | 10:01 AM
meborder's Avatar
meborder
vacuum leak causing lean condition causing pinging ...
everyone who said pinging raise thier hand
glad to hear you got it fixed.
and a good lesson to everyone that even new cars can suffer from old-school problems.... i wouldn't have guessed vacuum leak.
Old Sep 15, 2012 | 10:49 AM
  #28
Swiper's Avatar
Swiper
Does not sound like it was a pinging problem!
The dealer changed the T fitting to the hub.
The IWE was engaging from lack of vacuum is what i read as the problem.
I might be wrong though.
Old Sep 15, 2012 | 08:36 PM
  #29
rjmogs06's Avatar
rjmogs06
Yes my issue wasn't pinging it was the hubs engaging with the lack of vacuum believe this is referred to as a ratcheting noise definitely not pinging
Old Sep 15, 2012 | 08:42 PM
  #30
meborder's Avatar
meborder
win some lose some LOL
can't blame a guy for wishfull thinking.
lesson learned still, though. old school problem still exist and problem solving skills still can't be replaced by a code scanner.
