2003 6.0 FICM problem
Old Jan 4, 2011 | 04:42 PM
shamrock442's Avatar
shamrock442
i have a 2003 f250 6.0 it has a banks six gun with speed loader i went to start it the other day and warm it up and it ran for a while then stalled out then restarted no problem, drove it and while driving it stalled going down the road and again restarted no problem. Then i changed the fuel filters and had it stall again while idling. drove it now i am seeing slight white smoke in the exhaust. and the batteries were dead, second time on that is it possible for a bad ficm to drain the batteries while sitting or for bad batteries to cause problems with the ficm? although once truck is running it should be the alternator putting the voltage there. but i think batteries for sure and probably a rebuild of the ficm. i thought when the ficm goes bad you cant restart it. any advise will be greatly appreciated thanks.
Old Jan 4, 2011 | 04:45 PM
gearloose1's Avatar
gearloose1
You cannot test the FICM with bad batteries / alternator / cables.
Fix that first.
Then follow the TSB to test the FICM.
Polkster
Mar 24, 2014 07:40 PM
Farmin247
Feb 9, 2014 06:49 PM
bhicks28
Apr 26, 2012 01:45 PM
justin.ornellas
Dec 16, 2011 11:21 AM
FordMan35
Dec 24, 2009 09:50 AM
