This is an oasis of my truck and the question is, is the 13-sep-2005 the build date and 24-aug-2006 the sail date I was told it was out of warrenty trying to find out before EGR cooler / oil cooler replacement.
Chris
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTSW21P06EBXXXXX T/F7 F T/BC T/BD T/E A1 T/BE T/YB 13-SEP-2005 24-AUG-2006 121026 USA 26 1B03 030204 3C3Z 6A642 AA L65 42 44061
AWS Claim Key: 7289802 Trx Code: E72 Labor Hrs: 13
Dlr Cd-Sub Cd: 06723 - *
Cust Comments: SES LIGHT CAME ON,HEAR GRINDING NOISE AND CUT OFF
Tech Comments: VERIFIED CONCERN VISUAL CHECK FOUND OIL IN COOL ANT PRESSURE TESTED CALLED HOTLINE AND WAS REFE RED TO TSB 072314 REPLACED OIL COOLER EGR COOLE R HEATER CORE ALL HEATER HOSES AND BYPASS HOSES AND DEGAS BOTTLE FLUSHED COOLANT SYSTEM REMOPV ED BLOCK PLUGS TO GET OIL AND WATER MIXTURE FRO M ENGINE BLOCK HAD TO FLUSH SYSTEM 6 TIMES TO G ET FLUID TO ACCEPTABLE CONDITION NO LABOR OPS F OR MT IS FOR
At the moment, I am recommending the BulletProofDiesel EGR cooler and the factory oil cooler, unless you are doing heavy HP / Towing, then there is a case for the BPD external oil cooler.
