Overheat Problem *Roadside Emergency*
Old Jan 4, 2011 | 02:51 PM
orng1's Avatar
orng1
I bet it just froze. Let it idle for a while and keep an eye on the gauges.
Old Jan 5, 2011 | 07:43 PM
Flyin5's Avatar
Flyin5
Well it turned out to be the thermostat. Went back down to the truck last night, picked one up and threw it in and was good to go! Thanks guys!
Old Jan 5, 2011 | 10:23 PM
gradyc's Avatar
gradyc
wellhead
Originally Posted by jetdoc
Be careful with the T stat housing bolts....They have been known to break off in the water pump....
Yep,Just broke one off last month. Had to drill it out and install a bolt.
Old Jan 6, 2011 | 07:59 AM
Supercab's Avatar
Supercab
Wink
What about your coolant?? good time to flush and replace with the tremps you are experiancing.
Old Jan 6, 2011 | 08:50 AM
just another truck's Avatar
just another truck
Originally Posted by onelionhunter
if it isn't the t-stat, any chance you have old coolant that froze, about all I can think of otherwise
x2 on this...
Old Jan 6, 2011 | 09:09 AM
cj45lc's Avatar
cj45lc
Glad you got it fixed
Old Jan 6, 2011 | 09:14 AM
Ford79's Avatar
Ford79
Coolant in his truck is about 10 months old, just went in late March last year with the engine rebuild.
It is possible that it is not a strong enough mix for the temps though. Another thing to check.
parkland
6.4L Power Stroke Diesel
Aug 5, 2012 01:17 PM
Studawg
Feb 25, 2011 12:44 PM
energizedsbs
Jun 7, 2010 02:26 PM
guitarking135
1997 - 2003 F150
Mar 22, 2009 06:28 AM
Scott G.
1997 - 2003 F150
Nov 9, 2004 12:12 PM
