Ford 10.25 u-joint flange
So, I switched out my short spline to long spline ford 10.25 rear driveshaft yoke, went to bolt the u-joint straps back in, and then realized the yoke I have is threaded. Not only was it different there, it was about a 1/8” wider than the u-joint strap that I have. This is a used/newer model 10.25 yoke I’m using, so I’m not sure if it’s a different size u-joint, but it’s definitely the wrong spacing and/or style strap. Anyone have the same problems? Does the long spline shaft have bolts and a strap or just a wider u joint?
Johnkimble
06-12-2019 11:00 AM
FLgargoyle
09-15-2018 09:04 PM
herbiemin
09-07-2016 08:20 PM
Daniels54
07-30-2016 11:02 PM
4x484150
20
01-29-2013 10:50 PM
