Sponsored by: Auxito
must pull engine to repalce head gasket?
Old Jan 3, 2011 | 07:39 PM
hornsurgeon's Avatar
hornsurgeon
is there a way to replace the headgaskets on my 2000 f150 5.4 without pulling the engine?
Old Jan 3, 2011 | 08:21 PM
torkum's Avatar
torkum
Yes but I would rather pull the engine. The main problem is alignment of the head and the rear head bolt clearance. Alignment can be greatly helped by using a engine host to guide the head into position.
Dealers pull the cab off.
Old Jan 4, 2011 | 12:52 PM
ALLDATAdiy INFO's Avatar
ALLDATAdiy INFO
Former Vendor
ALLDATAdiy shows the first step is to remove the engine. After looking at the Head gasket procedure in there I can see why, I can't imaginee doing it in the truck.
Old Jan 4, 2011 | 12:56 PM
vloney's Avatar
vloney
I've done it engine in and engine out. No reason to pull the cab. You can have the engine out in 2 hours.
dylansf23
Jul 5, 2014 10:24 AM
muscletruck7379
15
Jun 21, 2008 01:51 PM
bdsoper
1997 - 2003 F150
Jul 6, 2004 07:47 PM
nostarttireflat
Mar 19, 2004 10:38 PM
