High pitched squeel coming from engine compartment
Old Jan 3, 2011 | 05:28 PM
Froggman's Avatar
Froggman
I just bought a 2006 F150 SuperCrew with a 5.4L engine and since the weather has turned cold, I've noticed an intermittent high pitched squeel coming from the engine compartment. I've replaced the serpentine belt and the idler pulley plus another belt pulley but none of the above helped. I've also had two separete mechanics look at the problem and both are at a loss as to what could be causing the noise. The guess is maybe its an air leak coming from either the intake or vacuum lines. But nobody is really sure.
The noise seems to really become noticable when the temperature gets below 20 degrees and around 2000 rpms, but sometimes it happens at other times.
Has anyone had this same problem with this truck and/or does anyone know where this extremely annoying sound might be coming from?
Thanks in advance for any and all input.
Old Jan 3, 2011 | 06:11 PM
Joe04F150's Avatar
Joe04F150
Its the alternator, I also had the same noise...I just recently had to change the alternator...no more noise.
Old Jan 3, 2011 | 10:17 PM
irishammer's Avatar
irishammer
The '04's had the alternator whistle....not sure about the 06's. I thought they had it fixed by then.
Old Jan 3, 2011 | 10:27 PM
AspenGreenMetallic's Avatar
AspenGreenMetallic
Haha! Mine does the same thing! I tell my friends its my Banks twin turbocharger!!!
But seriously, its the alternator. What part is doing the whistling? Is it the bearings on the pulley or the vanes that cool it just behind the pulley?
Old Jan 4, 2011 | 09:28 AM
mercman86's Avatar
mercman86
Mine used to do it all the time in the winter when it was below 20 degrees. But only at 70 mph or higher. Sometimes it would do it under hard acceleration. Now it seems to be a lot quieter. Im in the south for most of the winter so I dont really worry about it since it dosent do it when its warmer out.
Old Jan 6, 2011 | 06:16 PM
Froggman's Avatar
Froggman
It's hard to tell where it's coming from since it only does it when it wants and I can't recreate it inside while revving the engine. I've seen 3 mechanics about it and no one has come up with a cause. But I can tell you that I'm getting extremely agitated!
Old Jan 6, 2011 | 06:22 PM
Froggman's Avatar
Froggman
Wouldn't the alternator make the noise a bit more consistently? This sound only happens periodically when it's cold. I've actually asked a couple mechanics about the alternator like you suggested and they don't seem to agree that this this the problem. However, you could very well be correct and they are just missing the problem!
Old Jan 6, 2011 | 07:00 PM
06F150Guy's Avatar
06F150Guy
Mine had that same issue was never something I could make happen it just did it when it wanted. I changed the belt nope not it, then on a long 600 mi trip on the way home the fan clutch seized!!! Then the truck roared like an angry lion!! Just something to keep in mind!!!
Old Jan 6, 2011 | 07:24 PM
Joe04F150's Avatar
Joe04F150
mine only did it when it was real cold out and usually only after sitting for a long period of time (overnight, or all day at work) and it would only do it for few minutes into the drive and then go away.
Old Jan 24, 2011 | 08:19 AM
toneill's Avatar
toneill
My truck does the same exact thing. I doubt it is the alternator. I believe it is the fan clutch because of the intermittent nature of the noise. It only does it when it is really cold outside. It makes the noise at around 2000 rpm also. The noise goes away if I hit the accelerator. I'm going to replace the fan clutch and we'll see what happens. 2006 F150 XLT.
Old Jan 25, 2011 | 11:02 PM
Froggman's Avatar
Froggman
Thanks and let me know if that works. The noise is driving me nuts!
Old Jan 26, 2011 | 08:51 AM
bigunit54's Avatar
bigunit54
My truck does a similar noise in the cold but only before it is warmed up all the way. The noise is like a "squelch" I guess you would say, it only lasts a little bit. Not a real concern for me.
Old Jan 26, 2011 | 09:18 PM
Froggman's Avatar
Froggman
He noise mine is making is like a squeal and it doesn't matter if the truck is warmed or not. It's puzzling because the noise is not consistent. It squeals for a short time, then it's fine. What is consistent is that the colder it is outside, the longer anymore annoying the noise becomes. When the temperature gets above 30 degrees, the noise is hardly noticeable.
Old Feb 2, 2011 | 10:36 AM
EScott's Avatar
EScott
4wd High
squeeling noise
I've got an 06 F150 that makes the same noise. A very high pitched squeel. It only happens when it is cold and is very sporatic. 19 degrees yesterday and it squeeled on and off for a 3 hour round trip. I was thinking about the water pump?? Isn't there a bearing in there that could make that squeeling noise?? I don't know. thats why I come here!
I also remember that it happens at start up when very cold.
Anyone know of warranty issues with the alternator or the fan clutch causing this problem??
Old Feb 2, 2011 | 05:03 PM
Oldguy4's Avatar
Oldguy4
This wouldn't cost much and would eliminate another possability. No one else has mentioned the power steering pump. But you can buy a little bottle of power steering pump conditioner and put in. If the squeel goes away, great, but if it remaines then it's not the power steering pump and it didn't cost you much.
