is this how to shim the trunnion bush's?
I think i worked out how...
the critical thing was discovering the pre-load toque on the bushings....
Method is...
assemble the hub minus the bottom scraper, felt...
do not tighten the trunnion bush bolts...
do not add the trunnion bolt spacers...
tighten the trunnion bolts to 10lb...
measure the gap between the bolt heads and trunnion caps...
take the bolts out, shim up the measurment taken and retorque to spec...
Method is...
1970XL351W
1999 to 2016 Super Duty
12-31-2013 09:39 AM
White97
13
12-07-2008 06:47 PM
