c6 shift points?
Old Jan 2, 2011 | 07:18 PM
79350Ranger4x4's Avatar
79350Ranger4x4
c6 shift points?
Hi , eveyone . I have a 79 350 ,400 engine with 4.10 rear end. Just wondering what the shift points are , mine shifts from 1 to 2 at about 10 mph or so and then from 2 to 3 at about 25 to 30 ... does this sound right... are there any adjustments if not?... also should i install a kickdown lever, mine is not there? thanks..
Old Jan 2, 2011 | 08:04 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The kickdown isn't absolutely needed.
To adjust the shift points you can turn the modulator screw. IN for higher points, out for sooner.
Josh
