Where to scan for codes?
Old Jan 2, 2011 | 03:28 PM
Capt.Schenk's Avatar
Capt.Schenk
I did a thread search, but couldn't find what I was looking for. Maybe I didn't look hard enough. Anyways, my truck has "missed" a few times over the past week. I changed the fuel filter, oil, and oil filter, and it's missed a couple of times since. The last time it "missed", the check engine light came on. I turned the truck off, set my DP Tuner back to stock, and then turned the truck back on, and the light hasn't come back on since.
What I'd like to find is a place close to me (north side of Houston, Texas) where I can scan my codes.
Old Jan 2, 2011 | 07:17 PM
izzybird's Avatar
izzybird
There are some members on here that are close to you. I'm sure one of them has the ability to read your codes. Here's a bump for you.
Old Jan 2, 2011 | 08:57 PM
Capt.Schenk
Thanks for the bump!
Old Jan 2, 2011 | 09:52 PM
Stewart_H's Avatar
Stewart_H
Can you describe the miss a little better? Was it more like a hiccup?
Does it happen more often if your wipers are on intermittent?
Which CPS are you running?
Stewart
Old Jan 2, 2011 | 10:03 PM
Capt.Schenk
It's more like a hiccup. It's happened four times; once on 12/24 (in the rain, without pulling my boat, in 80/tow), and three times on 12/29 (not raining, pulling my boat, in 80/tow). Each "hiccup" was slightly worse than the previous. The only time the SES light came on was the 4th (and last) time I had a "hiccup". I pulled my boat short distances over the weekend in stock-mode, then pulled it 100 miles @ 75mph in stock-mode this morning, and didn't have any problems. I bought the truck in 2004 with 100,000 miles, and I haven't changed the CPS. I now have 342,000 miles on the truck. I really doubt the previous owner changed it, but I'm not sure. I've been reading threads about CPS problems for a couple hours, and I'm hoping that is my problem. I have to put a lot of miles on my truck this week while pulling my boat (I'm kinda a traveling fishing guide), so I need to solve this problem quickly. I love my DP Tuner! I can't hardly stand pulling my boat in the stock setting anymore.
Old Jan 2, 2011 | 10:08 PM
Stewart_H's Avatar
Stewart_H
I had the CPS hiccup right after I bought my truck. A couple years prior, I'd had the CPS go out on my Ex, but it never hiccupped and I'd never read where that was a symptom before, so I wasn't sure what was going on.
When I posted my "hiccup" thread a couple years ago, someone asked if it happened when I had the wipers on intermittent. The wipers were never on, but I went out a few days later and while driving down the freeway, turned the wipers on and guess what! The engine quit, LOL!
I drifted to the side of the road, waited a few minutes, fired her back up, drove home and popped my spare CPS in.
I haven't had a problem since.
Stewart
Old Jan 2, 2011 | 10:19 PM
Capt.Schenk
Like I said, I'm hoping my issue is as simple as a faulty CPS, but my truck died as most threads describe. I've just had hiccups. Would a faulty CPS cause these hiccups without ever shutting off the engine? Also, would a code scanner give me a code saying that my problem is a faulty CPS? I'm really wanting to find an accurate scanner in my neck of the woods.
Old Jan 2, 2011 | 10:27 PM
Stewart_H's Avatar
Stewart_H
Yeah, I had the hiccups for awhile before it started shutting off.
Do you have a spare CPS?
Stewart
Old Jan 2, 2011 | 10:34 PM
Capt.Schenk
I do not have a spare CPS, but I DO have a Ford dealer a mile from my house, and I'm not working tomorrow, so I'll have a new CPS in about 8.5 hours
After I replace the CPS, will a scanner show whether or not my previous CPS caused the SES light to come on? I wonder if the dealer will scan for codes if/when they replace my CPS.
Old Jan 2, 2011 | 10:48 PM
Stewart_H's Avatar
Stewart_H
Dunno about the codes, but I do know dealerships like to charge a diagnostic fee to scan for codes and clear any that are present.
Stewart
Old Jan 2, 2011 | 10:51 PM
JamesHajek's Avatar
JamesHajek
I'd still get it scanned...You want to know what set the CEL.
Old Jan 2, 2011 | 10:54 PM
Stewart_H's Avatar
Stewart_H
I have no problem with that line of thinking, but don't do it at the dealership.
Stewart
Old Jan 2, 2011 | 10:56 PM
Capt.Schenk
As much as I'd like to see the codes, I don't want to pay the dealer $100 for them.
Old Jan 2, 2011 | 10:58 PM
JamesHajek's Avatar
JamesHajek
Find someone near you. Seems like more than half the people on the forums are from Texas! There has got to be someone. You will never fix the problem if you don't know whats causing it. And the code is there to tell you...
carltonwebb's Avatar
carltonwebb
u might be eligible for the free recall cps since u have had it that long and not changed it. Mine is a 2000 as well and I just had it done last week.
