X code spring question
Old Jan 2, 2011 | 02:55 PM
psd76's Avatar
psd76
I have a 2003 F350 with the plow package setup with x code front springs. I am the second owner. Its time to replace the x codes. My question is will the new ones bring the front somewhat level with the rear or do ineed a leveling kit with the new x codes.
Old Jan 2, 2011 | 05:25 PM
yme450's Avatar
yme450
they will get you close but it will still sit a little higher in the rear.
Old Jan 2, 2011 | 05:51 PM
psd76's Avatar
psd76
Thanks for the reply. I can deal with it being a little lower in the front.
How do I set up my signature for my truck mods. I can't find it in the user cp. Thanks
Old Jan 2, 2011 | 06:05 PM
joeyd61's Avatar
joeyd61
I believy you need 25 post befor it will allow you to set up a signature
Old Jan 2, 2011 | 06:24 PM
psd76's Avatar
psd76
That explains it then. Thanks.
Old Jan 2, 2011 | 06:37 PM
fordpowerstroke444's Avatar
fordpowerstroke444
I have a 2000 F250 SD,Crew cab,7.3.Automatic.4X4.I had saggy U code springs,and brand new B code rear springs.I wanted my truck to sit level.I bought a set of X code springs that had about 50000 miles on them from a salvage yard.I ended up cutting my U codes down to about 15 inches long and used them for an add a leaf.Truck wouldnt have sat level without them.My ride quality isnt too bad either.Hope this helps.
Old Jan 2, 2011 | 07:24 PM
psd76's Avatar
psd76
From what I've read you get 2" of lift with the X codes. I can deal
With a little tilt front to back
