ford points
Old Jan 2, 2011 | 12:04 PM
atvexpress's Avatar
atvexpress
ford points
i bought my son a 66 ford
i dont know anything about fords
it doesnt have spark
i also have power at both sides of the coil
no matter where the points are set at
any hepl would be great thankyou
Old Jan 2, 2011 | 12:12 PM
Confederate Diesel's Avatar
Confederate Diesel
Remove the condenser clip, and check again. It is the most likely culprit, if the points are set correctly. If you get spark after disconnecting it, replace it.
Old Jan 2, 2011 | 12:15 PM
garbz2's Avatar
garbz2
Check the cap for the carbon contact. It may be missing. Check the rotor for wear.
Also try a replacement coil. Do you have a full 12 at crank?
Garbz
Old Jan 2, 2011 | 12:21 PM
atvexpress's Avatar
atvexpress
im going to got try it
Old Jan 2, 2011 | 12:23 PM
atvexpress's Avatar
atvexpress
ive only been using a test light
i put a new coil on
everything else looks new including the wires and plugs
i will check it with a meter
Old Jan 2, 2011 | 01:01 PM
atvexpress's Avatar
atvexpress
when i hit the start button voltage goes from 12 -10
unhooked condensor clip no spark
is both sides of the coil supposed to be hot with the key on?
mine are
even if i manually open the points
16
Oct 25, 2015 03:28 PM
mr.precision
Virginia Chapter
Sep 14, 2015 09:05 AM
Pete L
Dec 31, 2012 05:14 PM
1968FordF100
Apr 29, 2012 09:22 PM
Snotpunk
Apr 21, 2011 05:03 PM
