Re in"Car"nation High Performance Heads
Do not know but there is another site you might wabt to check. I personnaly have not tried these heads but I heard some good things, for302 heads anyway.
Tri-State Cylinder Head - Chevy, Ford, Small Block, Performance, Aluminum Cylinder Heads
If you are interested in getting your current heads ported why not do it yourself. I did mine summer before last and it was not hard (first time)- time consuming yes but fun. Actually once you started it is very relaxing to do. Just don't go crazy, match the intake to heads (not gasket) and smooth out the exhaust for beter flow. Lot of information on porting.
Wayne
Wayne
There was this thread earlier this year: https://www.ford-trucks.com/forums/9...ust-ports.html
Scotty's dyno figures back up his claims. You don't get into the Engine Masters on BS.
If the heads don't come as a complete ready to bolt on assembly then they probably aren't worth it. They are an iron head too, so resale would be a concern with them as well. By the time you would buy all the new hardware and have them all machined with a good valve and seat job with a mild port and polish you probably could be into a decent set of aluminum heads for just a little more, maybe less if you look around some. I just got a set of D3's back from the machine shop with a $300 dollar tag on them and all I had them do was put new bronze guide liners in, mill them and spotface the head bolt holes.
Show us your flow bench. Show me your dyno results with the heads you have reworked. I hear a lot of Talk.
CaptinIPSC,
Scott builds good quality heads; if you can afford it get him to build you a pair of aluminum heads.
Bill
Bill we talked quite awhile about what I had, how I used my pickup etc.... His suggestion was the large valve ported DOVE heads. I have seen many people specify certain things in their build that ties the hands of the guy you're trying to deal with. He decided what he felt I needed based on the answers I gave him. I've had real good luck following the advice of the guys in the know and I feel confident that all will turn out good.
joe1954
08-04-2013 06:35 AM
restoringmy46
46
08-25-2011 12:22 AM
