E4OD Longevity
Old Jan 2, 2011 | 02:01 PM
catfish101's Avatar
catfish101
I am not trying to steal anyone's thead here i just have a quick question. I am looking at buying a truck that has the E4OD. Is this a good transmission even though it shifts "slushy" It seems like after reading this thread that nobody likes them.
I like standard trans just because.....but I will say that as I get older autos are nice for just driving around town.....As far as good. I guess they are as good as it gets other then an Allison of some kind. I know of people that have allot of miles on them and haul things....I guess my biggest thing against them is they power they consume from the motor. They are very parasitic.
Old Jan 2, 2011 | 02:47 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
iv found most people who dislike the E40D are those who have never had one.
the most common failure seems to be people keep driving them when something is wrong.
here's what i did to mine:
B&M SuperCooler Transmission Cooler #70268
B&M Universal Remote Transmission Filter Kit #80277
B&M Light Truck Shift Improver Kit #10025 - Installed STAGE 1. HEAVY DUTY
this makes for a nice firm "you feel it shift",but not neck snapping or anything.perfect.like when you release the clutch and go with a manual.just a positive,"im in the next gear feel" if you will.
and installed a temp gauge.if i see the temps raise when plowing(the only time she could get warm due to the grill being blocked by the plow/moving slow) i'll just stop,and the temps drop right off inside a minute.
if i plowed a lot,id just get a e-fan for the external cooler,so i wouldn't need to stop and wait.
i keep the temps low,so i wont do the 15k flush interval,but the normal 30k interval flushes.
those who keep driving them with the OD light flashing or other electrical sensor type issues get what they deserve.it's not the trans fault people don't know better to actually limp it home or tow it,and repair the problem before it costs them a trans.
same thing for those who let search between 3rd and 4th when towing.hit the od button if your on hilly terrain ya know.
basic stuff that seems to elude many.
no temp gauge? then your driving your trans blind!
if you don't change your oil in the engine every 3-5k on dino oil and the engine only lasts for 20-30k miles because of it.does this make the engine junk? no.
why is it then that some go beyond 30k max interval for changing the trans oil and that's somehow ok,and if it fails insides 100k the trans must be junk? silly.
like anything,proper maintenance is key.
E40D poll:
https://www.ford-trucks.com/forums/9...40d-trans.html
(some dishonest people without actually owning one have voted.so the results are unfortunately skewed. )
going to the playoffs. lets get to the superbowl pats!
Old Jan 2, 2011 | 07:45 PM
snaponprofile's Avatar
snaponprofile
I like the transmission myself. I blew it towing 9,000 lbs up a hill at around 90K. But that wasn't due to transmissions weakness but more the engines weakness. The engine was underpowered so it put loads of strain on the tranny that normally wasn't there. Now that I have a turbo, I can barely feel the shifts at all. I haven't towed with it yet and I will post when I finally do but I'm really liking it now. I might have to put a shift kit on it or transcommand if I don't like the way it feels with a heavy load.
jason gressley
Sep 15, 2016 05:25 PM
Goodstuff
Modular V10 (6.8l)
28
Apr 28, 2016 06:16 AM
txtruckin
6.7L Power Stroke Diesel
20
May 3, 2014 06:56 PM
meanv10
6.4L Power Stroke Diesel
Oct 18, 2013 09:08 AM
F-250 restorer
Dec 30, 2009 08:11 PM
