7.3 WONT START
Old Jan 1, 2011 | 07:35 PM
CHEMICALMAN's Avatar
CHEMICALMAN
7.3 WONT START
HEY GUYS, IT IS 36 DEGREES WHERE I LIVE AND I WENT OUT TO START MY 2003 F250 7.3L AND WHEN I TURN THE KEY THE GUAGES ACT FUNNY AND THEN THE TRUCK WILL JUST WEEKLY TURN OVER BUT NOT START.THE LIGHTS ARE KIND OF DIM AND THE UNDER THE HOOD LIGHT WILL NOT COME ON.IS THIS A BATTERY PROBLEM OR ALTERNATOR OR SOMETHING ELSE. THANKS FOR YOUR HELP
Old Jan 1, 2011 | 07:53 PM
carltonwebb's Avatar
carltonwebb
Sounds like battery. It takes a lot of amps and voltage to turn these engines when cold so strong batteries are a must have.
Old Jan 1, 2011 | 07:59 PM
CHEMICALMAN
I HAVE A BATTERY CHARGER,SHOULD I TRY TO CHARGE BEFORE PURCHASING NEW ONES .AND DO I NEED TO BUY 2 BATTERIES ?
Old Jan 1, 2011 | 08:06 PM
F350-6's Avatar
F350-6
Clean all your battery connections and grounds and stick the batteries on a charger. Loose/corroded cables can cause a no start also so don't overlook them.
Old Jan 1, 2011 | 08:14 PM
CHEMICALMAN
THANKS FOR THE HELP.
Old Jan 1, 2011 | 08:15 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Check your connections and clean them at your batteries and give them a charge and see what happens. Then take them and have them load tested. And yes change them in pairs (850 cca min).
Old Jan 2, 2011 | 12:39 AM
bluescrew's Avatar
bluescrew
YOU'RE TYPING IN CAPS LOCK.. PUSH IT and your text looks like this!
Sorry i couldn't resist
Old Jan 2, 2011 | 12:43 AM
f-250muddin's Avatar
f-250muddin
dose yours have a block heater?i have a 7.3l too but its a 95 and ive had that problem too
