Trac-bar bolt size?
Old Jan 1, 2011 | 04:18 PM
hhcobra's Avatar
hhcobra
Trac-bar bolt size?
Can someone tell me the size of the socket needed to remove the trac-bar. A 1-1/8 inch wrench is a little too small. Thanks
Old Jan 1, 2011 | 06:52 PM
Waltdog's Avatar
Waltdog
of American machinists
It is 30 MM. Or a 1 3/16 should be a nice fit. If these bolts have never been removed before you will need an impact gun or a very large breaker bar and pipe combo. They are torqued to 383 ft lbs plus red lock tight from the factory.
Old Jan 1, 2011 | 07:20 PM
hhcobra's Avatar
hhcobra
Thanks for the information Walt!!!!! Reps sent.
Old Jan 1, 2011 | 08:34 PM
hhcobra's Avatar
hhcobra
If I'm not going to be reusing the bolts for the trac-bar would there be any problem with cutting the heads off the bolts with a sawzall? It seems like that would be a lot faster than trying to break them loose knowing they are torqued to 385# with red locktite.
Old Jan 2, 2011 | 04:01 PM
Waltdog's Avatar
Waltdog
Fred I would not cut the bolts . They are over 18 bucks each and last time I checked they only sell them in packs of 4. Of course you said you plan on not re using them so what will take its place?
Old Jan 2, 2011 | 07:11 PM
hhcobra's Avatar
hhcobra
Pro Comp has a component kit that includes new U-bolts for the springs and a some cam adjustable bolts that allow you to adjust the trac-bar. It worked really well and was the easiest part of the spring swap. The bolts in the trac-bar broke loose pretty easy (less than 150#). The combination of cam bolts takes the place of the old bolts and allows you to adjust the trac-bar about 1/4 to1/2 inch. The new springs (Pro comp 22210) gave the X about a 3.5 inch lift. Thanks again for the help!!!
