tsb
Old Mar 5, 2003 | 04:30 PM
1988ford's Avatar
1988ford
tsb
Can anyone give me any information on the is Technical Service Bulletin?
Make: Ford Truck
Model: F150
Year:1998
Service Bulletin #: BC2503910201
Bulletin Sequence #: 001
Summary Description: Brake popping noise from front brake caliper suddenly springing away from the upper caliper abutment and returning
Thanks
Old Mar 5, 2003 | 10:03 PM
steve83's Avatar
steve83
tsb
That doesn't sound right - a '98 caliper should be the floating type, which doesn't have any abutments. Only the pads are retained that way.
Old Mar 5, 2003 | 10:46 PM
1988ford's Avatar
1988ford
tsb
Sorry. I meant 1988. don't know what i was thinking
Old Mar 5, 2003 | 11:32 PM
Racerguy's Avatar
Racerguy
tsb
That doesnt sound like a Ford TSB number. Can you check the number again? Where did you get that number from?
I dont remember ever seeing a TSB concerning the problem you're describing. There is one about the caliper pins seizing up but that wont cause a pop noise.
What kind of problems are you having?
Old Mar 6, 2003 | 09:07 AM
AlM's Avatar
AlM
tsb
yo,
I see that type of designation here, but for a '90 MARK VII
Service Bulletin Number: BC2503910201
Bulletin Sequence Number: 001
Date of Bulletin: 9102
NHTSA Item Number: SB022542
Make: LINCOLN
Model: MARK VII
Year: 1990
Component: BRAKES:HYDRAULIC SYSTEM
Summary: BRAKE POPPING NOISE FROM FRONT BRAKE CALIPER SUDDENLY SPRINGING AWAY FROM THE UP PER
CALIPER ABUTMENT AND RETURNING-ALL FORD RC
Old Mar 6, 2003 | 07:09 PM
1988ford's Avatar
1988ford
tsb
My 1988 ford f-150 is making a popping noise coming from the right wheel. It sounds like something to do with the brake to me. Anyways on this website I was looking through all of the Technichal Service Bullitens for my truck and found that. I asked ford and they said it wasn't from them. I thought someone here might know.
Old Mar 7, 2003 | 08:34 AM
AlM's Avatar
AlM
tsb
I didn't look through the 88 tsb's when i did the search for you. So I just went hrough the recall/tsb link (on right panel) to view the tsb's for the 88 and found what you discovered:
"Make: FORD TRUCK Model: F150 Year: 1988
Service Bulletin Number: BC2503910201 Bulletin Sequence Number: 001 Date of Bulletin: 02/91
NHTSA Item Number: 022687
Make: FORD TRUCK
BRAKE POPPING NOISE FROM FRONT BRAKE CALIPER SUDDENLY SPRINGING AWAY FROM THE UP PER CALIPER ABUTMENT AND RETURNING-ALL FORD RC..."
ask another serv dept to run that one or maybe someone here in FTE can find the compl. tsb for you.
Kyle Barrett
Aug 22, 2010 09:06 AM
blueharley
Jun 15, 2006 11:21 PM
gbeach
Jul 13, 2004 03:41 PM
scottb1014
2004 - 2008 F150
Mar 29, 2004 05:45 PM
byrni
1997 - 2003 F150
Dec 22, 2003 08:52 PM
