Transmission filter leak - 06 F350
I have got a transmission fluid leak in the vicinity of the external transmission filter on my 06 F350. Can I get away with leaving this or will I be in trouble if not repaired? It is my understanding that the external filter acts as a bypass and only sees a fraction of the oil pressure that exists in the transmission housing. Is this correct?
I had this happen after replacing my filter on my 06. I found that the o-ring that was on the toilet paper filter holder cup was the culprit. From now on every time I replace the filter I will be replacing the o-ring. I would start there.
Mine leaked for about 2 weeks till I could get to fixing it. So if you a leak for a while I don't think it will be to much of a problem unless you run low on fluid.
Cheers!
Cheers!
Norton72
04-16-2016 02:47 PM
reptar0077
1999 to 2016 Super Duty
29
02-08-2016 07:17 PM
Macs1964F100
07-23-2014 01:39 AM
