fuel not pumping
Old Jan 1, 2011 | 12:15 PM
ford4x4s's Avatar
ford4x4s
fuel not pumping
2000 f350...fuel filter cover off....turn key on and can hear pump run for few seconds, all i get is air bubbles in filter...didnt see any broken line and pulled pickup out of tank and it looked good....any ideas
Old Jan 1, 2011 | 01:31 PM
rbaker6336's Avatar
rbaker6336
Did you try it with the filter lid on?
Old Jan 1, 2011 | 01:39 PM
PaysonPSD's Avatar
PaysonPSD
The screen on the inlet side of pump might be clogged.
Pump should run about 20 seconds with each cycle of key.
Old Jan 1, 2011 | 01:45 PM
HD Rider's Avatar
HD Rider
Originally Posted by ford4x4s
2002 f350...fuel filter cover off....turn key on and can hear pump run for few seconds, all i get is air bubbles in filter...didnt see any broken line and pulled pickup out of tank and it looked good....any ideas
You said you pulled the pickup out of the tank. Did you take the white plastic can apart and check the screens inside?
Old Jan 1, 2011 | 01:52 PM
PaysonPSD's Avatar
PaysonPSD
Good point Paul.
Old Jan 1, 2011 | 02:07 PM
clintbonnie's Avatar
clintbonnie
See if you get your fault codes read.. look for P0230, P0231 or P0232..
Old Jan 1, 2011 | 03:29 PM
ford4x4s's Avatar
ford4x4s
lid on makes no difference, i did not take white can apart but i did put plastic bag over main screen to see if there was any suction and there was not. truck has been dieing intermittently lately, and then running ok after sitting a day or so. its my fathers farm truck which isnt maintained well, and he lost his fuel cap for a few days so who knows what gets into his tank, but it was amazingly clean looking when i opened it up but filter is always dirty. also its in connecticut so does get below freezing but he puts heat in fuel. the bubbles coming into filter are pretty large as if blowing bubbles in your water cup with a straw. when i had pickup out, no fuel returned to tank either
Old Jan 1, 2011 | 03:35 PM
clintbonnie
Try removing the fuel line off the back of the fuel pump and attach a new fuel line. Put the other end into a bucket of fuel and cycle the key.. check the fuel bowl with the lid off again..
Old Jan 1, 2011 | 07:40 PM
dn29626's Avatar
dn29626
I think everyone is hinting towards the hutch mod (me too).
Welcome to guzzle's In-tank Hutch Mod Web Page
Old Jan 3, 2011 | 11:13 AM
ford4x4s's Avatar
ford4x4s
solved!!!!! well i hooked a seperate fuel line to pump and dropped into fuel can and it sucked right up. after pulling pickup out of tank again i took the white plastic thing apart to find it a little dirty but not bad. then i took a good close look at everything and found a crack in the little red rubber mouth thing, which was above the fuel level. put new rubber thing on....put back together....and turned the key and it filled filter housing right up! thanks for the tips guys, i really appreciate them all!
Old Jan 3, 2011 | 11:24 AM
clintbonnie
Hey.. good news.. glad you got it fixed.. !!
StewB
Nov 17, 2025 04:32 PM
Creepin4x4
Jun 20, 2016 09:22 AM
bashby
21
Jun 7, 2015 08:19 AM
MonArt60
Oct 31, 2014 01:45 PM
rob71458
Aug 28, 2009 08:31 PM
