My blower motor runs with the truck off and key in my pocket. Its really wet out and all snow is melting could this be water dripping onto my Gem this has never happened before wasnt even like that last night.
Might be a stuck relay, check the owners' manual for the relay location in the fuse box under the hood and pull it out and swap it with another one to see if that is it. Should only take a minute and is easy.
[quote=bayou barataria;9758846]Might be a stuck relay, check the owners' manual for the relay location in the fuse box under the hood and pull it out and swap it with another one to see if that is it. Should only take a minute and is easy.[/quote
Tried it does the same thing with a new relay i think the Gem got water on it.
Do you have the manual heater controls?
As far as I know 99's blower control isn't via the gem module...So if its not the relay check for melted wires under it.
Ben wrong B4.
Isn't there a thread about water leaking on the back of the fuse panel and causing problems? Try to dig it up, if I remember right you have to pull the fuse panel out and check behind it for corrosion. It could also be a bad control panel for the ac and blower.
