5.4 2v
Old Dec 31, 2010 | 03:00 PM
hollenjoe's Avatar
hollenjoe
5.4 2v
I posted in the f 150 section but got no reply, so im moving it here:
How you doing, I just bought this truck for cheap, its running strong.
It has the 5.4 2v engine and ive been reading for a while and ive decided on a list of mods im gonna do to it, they are:
1. OBX Long Tube headers, custom off road true dual exhaust , 2.5" tubbing and cherry bombs
2. The Intake and o2 Gotts mod
3. k&n cone filter
4. True trac lock limmited slip
5. switching the 3.55s to 4.11
6. Troyer Performance Dual 16" Electric Fan Kit for 1997-2003 Ford F-series
7. Gryphon Cts with the dashboard adaptor
That is pretty much decided and i will order everythng on the list at once.
Ive built several engines but i have never even as much touch one of these modular ones. So I was wondering if maybe with the stock heads i would benefit from gettng the comp cam extreme energy xe268h? or should i get the xe262h? the cost is indiffernt to me. If so will the stock springs and retainers work? And will i have to remove the head to change them or is there any specific spring compressor to use?
Anyone with any nfo will be much appreciated,
Thanx
Joe
Old Dec 31, 2010 | 05:32 PM
guitar maestro's Avatar
guitar maestro
I don't wanna say "DO NOT!" (even though I really do, lol), but I highly suggest you stay away from camshafts that are not designed for "trucks". Those comp cams you listed all shift the torque & power up on the RPM band. IMO, this is something you don't want, because then you will [unfortunately] realize how the stock truck intake manifold is designed for low-mid RPM torque, and not high-RPM horsepower. No matter what you do, you won't be able to change those long, skinny runners on the stock intake that promote low-RPM velocity.
I suggest you read this:
ModularHeadShop Bullet Cams
and this:
http://www.modularheadshop.com/FAQ/2V%20cams.htm
and since you're new to modulars, read this about timing:
http://www.modularheadshop.com/Artic...stallation.htm
Old Dec 31, 2010 | 07:26 PM
galaxie641's Avatar
galaxie641
PI or NPI engine?
Old Jan 1, 2011 | 08:48 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
Guitar maestro is right.Go drive a chevy truck with the 5.3 vortech. Pulls like a car engine in a truck. Doesn't make power til 3k rpm.You need a truck cam.
IMO I would skip all those mods but the electric fans and gears and put a procharger onit.
Old Jan 2, 2011 | 03:29 AM
STOFFERJ's Avatar
STOFFERJ
also changing cams will require valve springs change and at least 24# injectors
Old Jan 2, 2011 | 10:33 AM
hodges710's Avatar
hodges710
Just passing on that the 97 and 98 5.4 are junk, not sure what year yours is.
Old Jan 4, 2011 | 08:43 AM
hollenjoe's Avatar
hollenjoe
Thanx , and sorry mine is a 2002 engine, so yes its a PI, any link to a procharger unit?
Thanx
Old Jan 4, 2011 | 10:15 AM
EXCURSIONATOR1
ProCharger Truck/SUV Systems
http://www.f150online.com/forums/sup...t-em-here.html
Old Jan 4, 2011 | 05:08 PM
hollenjoe's Avatar
hollenjoe
Thanx alot
Old Jan 4, 2011 | 05:10 PM
hollenjoe's Avatar
hollenjoe
has anybody tried the trick flow heads on a stock 5.4? they offer the best performance for the buck as ive read
Old Jan 5, 2011 | 02:00 AM
STOFFERJ's Avatar
STOFFERJ
they cost low end power, but gain top end power
Old Jan 9, 2011 | 08:20 AM
phil6608's Avatar
phil6608
Thanx
Do a Lightning intake assembly swap.
Old Jan 12, 2011 | 10:45 AM
hollenjoe's Avatar
hollenjoe
Ok thanx, I have another question, I bought the OBX long tubes which come with resonators and no cats, ive also bought the gryphon cts, since the gryphon takes a while to ship, Is there any performance/engine trouble if i ran the obx with the engine light on? Besided the engine light is there any trouble running cat free? (its an offroad truck so Im not asking bout the law),
thanx
Old Jan 13, 2011 | 03:23 PM
hollenjoe's Avatar
hollenjoe
Bump
So no idea if i would have any trouble besides the cel Until I get my custom tune?=
Old Jan 16, 2011 | 04:57 AM
phil6608's Avatar
phil6608
You can put the headers on with out a tune. No problem other then the light.
