Wiring and Switch suggestions?
Old Dec 31, 2010 | 07:47 AM
Confederate Diesel's Avatar
Confederate Diesel
I am looking for suggestions on some wiring I want to do to my 2000 Superduty. 1. Does anyone have an idea for switches in the dash/console area other than drilling extra holes all over the place? I intend to install some driving lights up front and some high power backup lights on my topper. The lights in the back will run off a relay and will be triggered off the backup lamps. However there may be times I want to switch them on without keeping the truck in Reverse to keep the backup lights on. 2. My flatbed trailer has a winch now, and it works great - except that I have to lug an extra battery around. I would like to wire up a plug-in power source to the rear of the truck to run the winch. My initial idea is to install a second trailer-plug, (4 pin?) with a long lead from the batteries up front, but I am not sure if it will carry the amperage. What have you all done? Thanks!
Old Dec 31, 2010 | 08:27 AM
jd58980's Avatar
jd58980
As far as the winch on the trailer goes, I have mounted the winch and battery on the trailer. Placed an isolator on the trailer also. Ran a heavy guage wire to the rear of the truck, have a heavy duty plug (like a forklift connection) and then run the other end to the isolator. That way the battery can feed off the main batteries, be charged and with the isolater, the trailer battery can not back feed the mains.
Old Dec 31, 2010 | 08:31 AM
F350-6's Avatar
F350-6
Sounds like you'd be a good candidate for the 650 dash so you can install as many switches as you'd like. If not, I've always like the clean look of installing small rocker switches above the fuse panel like this
For the power wire, you can choose from different sizes of cable connections like they use to charge electric forklifts or hook up the jumper cable quick connects.
Old Dec 31, 2010 | 09:36 AM
Jbrown8988's Avatar
Jbrown8988
F-650 dash mod!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 31, 2010 | 09:40 AM
Ponyboychris's Avatar
Ponyboychris
X2
Old Dec 31, 2010 | 12:49 PM
SpringerPop's Avatar
SpringerPop
Here's what I did:
SpringerPop's Upfitter Switches
Pop
Old Dec 31, 2010 | 03:44 PM
carltonwebb's Avatar
carltonwebb
do they sell the f-650 dash in tan ? If anyone knows....
Old Dec 31, 2010 | 04:34 PM
bluescrew's Avatar
bluescrew
u buy it in grey and spray paint it.. i think?
Old Dec 31, 2010 | 05:16 PM
Confederate Diesel
That F-650 mod looks really nice - I'll have to save up for it! And yes, it comes in 3 colors of Tan, '99, '00-'04 and '04 - later, according to Cliff's site! Thanks for the help on the connectors; I haven't seen those before.
Old Jan 4, 2011 | 08:14 PM
Confederate Diesel
The first part of getting more backup lighting is done! I picked up a set of "driving" lights, one of those oval shaped sets, and mounted them on the top of the backside of the canopy, above the rear window, but not so high they might get scraped off by a branch. I drilled one hole for the bolt, and a second one for the wires, and sealed the backside of the brackets and the wiring holes with some RTV. Very easy to do. One wiring option was to tap into the OEM backup lights to trigger a relay for power to the halogen ones. However, I looked at the circuits on the trailer connection, and saw the one for trailer backup lights so I tapped into it directly. Now they automatically light up in Reverse, and rated at 20A that source is more than needed for the halogen lamps. I wish I could post a picture, but the difference is great, and I finally have enough light!
Old Jan 4, 2011 | 09:25 PM
Waltdog's Avatar
Waltdog
of American machinists
Another option is the 05-07 upfitters, It comes pre wired with 4 load capable (2 10amp and 2 30amp) switched relays.
https://www.ford-trucks.com/forums/4...info-here.html
phydeauxman
All Things Towing
13
Jun 2, 2020 03:49 PM
cadjak
35
Sep 16, 2015 08:12 PM
psicorp
Mar 26, 2014 11:12 PM
stephendudra
Sep 9, 2012 07:38 PM
UNTAMND
Aug 27, 2012 12:24 PM
