Fuel tank issue.
Old Dec 30, 2010 | 07:05 PM
konawizard's Avatar
konawizard
Fuel tank issue.
Just got a 91 f250. Last week I filled both tanks. Front guage acting bad, never went above half tank. Drove about 100 miles. Filled it today, 8 gallons. Gage never went above half aigin. 20 miles later gage showed empty, at the 40 mile mark truck stalled, running out of gas. Rear tank was full, gage showing full also. How did the vapor lock thing happen? Truck runs well, no smoking, hesitation, etc. Since the first fill up I have been running on front tank, till ran out today. Vapor lock? Bad fuel pump? Opinions please......
Old Dec 30, 2010 | 10:19 PM
boots6868's Avatar
boots6868
someone maybe stole gas out of your front tank? hole in the tank/lines if you got a ruptured line she will empty out right quick. gotta start somewhere.
Old Dec 30, 2010 | 11:02 PM
CWPottenger's Avatar
CWPottenger
Front tanks are real prone to rust failure!! also pump switch valve can malfunction in such a way that it turns into a transfer valve in which one tank just empties into other..
Old Dec 30, 2010 | 11:07 PM
g_k50's Avatar
g_k50
brass float has fuel in it that's throwing off the balance and reading, remove fuel pump and sender and replace float.
Old Dec 31, 2010 | 12:09 AM
MONSTERPRE's Avatar
MONSTERPRE
91's shouldn't have that valve...they are individual pumps inside of the tank with a dash switch that engages each pump separately.
Old Jan 1, 2011 | 11:25 AM
boots6868's Avatar
boots6868
yeah 91s had that valve. I had a 89 f150 4x4 lariat with 2 tanks i bought brand new in 89, at about 125k if i had both tanks full and was using off the back tank it would overfill my front tank. i always had to use the front tank first.
Zero Dragon
1983 - 2012 Ranger & B-Series
Dec 14, 2011 04:17 PM
Judd944
23
Jul 30, 2010 07:39 AM
Kart18
23
Apr 12, 2010 05:23 PM
wrangler
Sep 28, 2003 07:58 PM
