Door lock clip?
Old Dec 30, 2010 | 05:47 PM
crashtke's Avatar
crashtke
Question Door lock clip?
There is a little clip that holds the rod attached to the tumbler in the door to the locking mechanism....this little clip pretty much came apart from rust and age. Is there ANYWHERE that I can get another one of these odd ball little clips? As it is, every time I try to lock the door using the key from the outside, the rod slips and I am unable to lock the truck.
Old Dec 30, 2010 | 05:58 PM
OldHarley's Avatar
OldHarley
Yeah, it'll do that.
I found one of those clips at the hardware store, but it was the wrong hand... that is, once the locking rod went thru the two rings, the part that clips to the rod was on the wrong side.
As I recall I modified the clip by removing one of the rings and I believe it worked. Would have been nice to find the right part, though.
Not much help, am I?
Old Dec 30, 2010 | 06:00 PM
crashtke's Avatar
crashtke
It's a thought I guess...wonder if I could soder it back together? Probably would not hold very long. Seems that you could use some kind of a rubber piece on either side or something. It is overall a stupid design with that little hook.
Old Dec 30, 2010 | 06:05 PM
OldHarley's Avatar
OldHarley
Right.
If that clip ain't there, the rod slips in too far and there is your problem.
I doubt solder would hold since the clip is spring steel. I was surprised to find it locally at a hardware store and equally surprised that the one I found was the wrong hand (all sizes I found were wrong that way). The ones I found were called an accelerator rod clip. And, I have had several vehicles that had this same clip on the accelerator rod (only larger), so I guess the name makes sense.
Maybe there's another fix, so I'll shut up and leave this to someone else that has solved it.
Old Dec 30, 2010 | 06:14 PM
crashtke's Avatar
crashtke
Well thanks for the tip. Worst case I can try to "engineer" one of the actuator rod clips
Old Dec 30, 2010 | 06:18 PM
OldHarley's Avatar
OldHarley
If you look at the photo I just added above, you will notice you have to cut off the single 'ring' to make it work, I believe.
OR, there is probably someone here smarter that can refer us to the right item.
Old Dec 30, 2010 | 06:27 PM
crashtke's Avatar
crashtke
Wonder if this one from a bronco would work?
Tom's Bronco Parts - Door Rod Bushing Clip, OE Metal Style, 66-67 Early Ford Bronco, New
or this one?
http://shop.advanceautoparts.com/web...___#fragment-3
Old Dec 30, 2010 | 06:30 PM
ford390gashog's Avatar
ford390gashog
You can upgrade it to the more modern nylon style from a 73-79 those are easy to get and direct fit.
Old Dec 30, 2010 | 06:39 PM
crashtke's Avatar
crashtke
Would that be like the one in the second link I posted just above?
Old Dec 30, 2010 | 07:08 PM
65jim's Avatar
65jim
Might be able to find one at the local AUTOMOTIVE RECYCLING & DISMANTLING FACILITY ( your local junkyard)
Old Dec 31, 2010 | 04:46 PM
crashtke's Avatar
crashtke
The damn bronco place wants $12 to ship a $3 clip. FORGET that. I will engineer something before paying $16 for a $3 clip!!
Old Dec 31, 2010 | 05:25 PM
camperspecial65's Avatar
camperspecial65
I believe i have a few of these clips...the one that holds the 3" or so rod to the lock cylinder assy...drop me an email with the pertinent info...or post your email and I can shoot you an email..you will love the price :-)
- cs65
Old Dec 31, 2010 | 05:33 PM
crashtke's Avatar
crashtke
Sent ya an email.
