1978 - 1996 Big Bronco
Battery keeps draining
Old Dec 30, 2010 | 05:26 PM
Wicked Endings's Avatar
Wicked Endings
We just bought a brand new battery a few weeks ago, and just the other day, the battery was drained, the radio would turn on, but not enough power to turn it over. I jumped it, let the truck run for about half an hour, then shut it off. Next morning, the battery was deader than dead. Radio wasn't even turning on. No lights, no anything.
What could make it do this?
Old Dec 30, 2010 | 11:24 PM
Grogtronics's Avatar
Grogtronics
I would suggest taking your alt off and having it tested first
Old Dec 31, 2010 | 12:44 AM
greystreak92's Avatar
greystreak92
Definitely be certain the alternator is charging. If it isn't, replace the burned out "battery" indicator lamp in the dashboard... which SHOULD glow while the engine is running if the alternator is not charging the battery.
If the alt. is good, check for short circuits. This is best done by removing fuses one at a time and taking a test light across the fuse terminals in the block. If there is any draw on the circuit being tested, the test light will glow. The only fused circuit that might have some draw with the engine off would be the constant power for the radio which allows it to keep preset and clock memory.
Old Jan 1, 2011 | 07:07 PM
Black Ford XLT's Avatar
Black Ford XLT
Wicked i had this happen to my 1985 f-150. I got lucky and found the relay under the dash for the choke had shorted (yes shorted) and power from the choke wasnt cutting off. So after finding out the price for a new relay ,i opted to make my own, traced all wiring and the relay i rewired is still in the truck working now .The relay killed 2 brand new sears die hard battieries . Hope this helps TR
Old Jan 1, 2011 | 07:16 PM
85e150's Avatar
85e150
Had a similar problem with my '85. The relay was for the carb purge set up. It would "tick" for a few seconds after shutdown, then turn off. But the relay went bad and it would "tick" away till the battery died, usually took a couple of days. $26 at the time. Ford mechanic at work tipped me off to it, and the Ford parts guy knew exactly what I was talking about. That tells me it's a common problem, so maybe you have something similar.
Old Jan 1, 2011 | 07:35 PM
Black Ford XLT
85. i think when it happened to my 150 ,the relay was 79 bux, i know now the relay i used ,i wired it to come on (after the switch is tured on)been working for 8-9 years TR
Larry Wall
24
Dec 8, 2022 12:52 PM
snickerman
Feb 3, 2011 09:45 AM
bigal6030
Jan 11, 2010 10:07 PM
G4ORCEBOYS
Escape & Escape Hybrid
Dec 21, 2009 12:09 AM
JFH
Aug 13, 2007 07:54 AM
