Sponsored by: Real Truck
Stalling !!??!!
Old Mar 5, 2003 | 12:09 PM
EJEther's Avatar
EJEther
Stalling !!??!!
Ive got a 1988 F250 EFI 351. It idles fine but when I step on the gas from a stop it dies for a sec and then catches up again, sometimes it will stall out completely esp if it has been idling along at low speeds before I stopped. I am stumped: Ive done the plugs, wires, cap, rotor, feul filter, PCV valve, I cant find any vacuum leaks (anymore)......
I need some help, Thanks yall.
Old Mar 5, 2003 | 12:42 PM
NoMo's Avatar
NoMo
Stalling !!??!!
Have you checked the throttle position sensor? Sometimes they go "bad"- specifically, their resistance becomes non-linear.
Old Mar 6, 2003 | 04:17 AM
chris93's Avatar
chris93
Stalling !!??!!
ive got a 93 f-150 302.it was acting like that b4 the low pressure in tank fuel fump went out.
Old Mar 6, 2003 | 09:15 AM
Waxy's Avatar
Waxy
Stalling !!??!!
Welcome aboard EJEther.
Dollars to Donuts your problem is one or both of your in tank fuel pumps. I had to replace both on my '89 F250HD 351W, same symptoms as you're describing.
You can buy them new from Ford (only ), or try your local wreckers if you don't like the sticker shock.
They're simple to change out, just disconnect the filler hose, undo the clamps, lower the tanks (run them empty first!), unbolt the old pump, bolt the new one in, and reverse the process. Shouldn't take more than an afternoon and it can be done in the driveway with a minimum of tools. Get a buddy to help manouever the tanks around though.
Good luck,
Waxy
Old Apr 19, 2003 | 01:32 PM
EJEther's Avatar
EJEther
Stalling !!??!!
Hey, Its been awhile but it anyone cares, the problem was a dirty throttle body. Took it in to a shop and for 106.03 they told me there were carbon deposits and they cleaned it out. Now why didnt I think of that....
Any hints on what causes that and how I can stop it from happeneing anymore?
Thanks
Old Apr 20, 2003 | 10:15 AM
ENC's Avatar
ENC
Stalling !!??!!
carbon buildup on the throttle body is just a thing that happens.
I work at a service shop and we sell a fuel injection cleaning service as preventative maintenance. I have also seen it do wonders to cars that were very badly mistreated.
We charge about 60.00 and I do one on my cars about every 30,000 miles. You can buy DIY stuff from auto part stores also. Seafoam from NAPA comes to mind. However shops like mine have equipment to make it an aresol and spray into the engine that seems to work better than DIY. I saw an '85 Audi blow grey smoke rings 7 feet out the exhaust pipe and it ran like a new car afterwards pretty cool.
jduggan43
Sep 30, 2013 10:29 AM
RDouglas
1997 - 2003 F150
Apr 22, 2009 08:39 PM
94FordGuy
Aerostar
Feb 10, 2004 10:28 AM
radicimo
Jun 17, 2003 08:33 PM
hotdog2000
Feb 21, 2003 12:47 AM
