Sponsored by: Real Truck
engine swap
Old Dec 29, 2010 | 02:04 PM
richk136's Avatar
richk136
Question engine swap
i havea 1997 ford van wit a 5.4 engine. d does anyone know if its possble to put a 5.0 engine from an 73 ford van to replace the 5.4 without alot of problems for me. any help appreciated
Old Dec 29, 2010 | 03:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, it's possible, but when you added without a lot of problems, no, that's not going to happen. There will be A LOT of problems getting that to work.
Old Dec 29, 2010 | 04:36 PM
richk136's Avatar
richk136
can't i just use the gas tank from the 5.0 and eleminate the computer. but will it fit in or do i need engine mounts and a different trans. thanks
Old Dec 29, 2010 | 06:07 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, because the transmission is computer controlled also. So, replace the engine and transmission...oh wait, the 1973 Ford has a carb so you will need to redesign the fuel system. OK, not a huge deal...at least the radiator will work.
Not sure why you would want to do this. Seems like a huge step backwards?
Old Dec 29, 2010 | 08:40 PM
cparks's Avatar
cparks
It would be a lot of work, but anything is possible with any vehicle. The trans is different, the engine mount and trans mount will be different, you will need a longer drive-shaft, the cable bracket for the trans shifter will need work, exhaust work to hook up to the manifolds, I think the speedometer is driven through the engine computer speed sensor, not not sure if that will work without the engine computer, need to work on the fuel tank pickup potentially removing the electric pump from inside the tank and running some new fuel lines and probably a few other things I am not thinking of. Plus if you have to do an emissions test, that will be an issue. If the van need a motor, you would be better off IMO to replace it.
Old Dec 29, 2010 | 08:41 PM
cparks's Avatar
cparks
Yes different mounts and different trans, plus a bunch of other things.
Old Dec 29, 2010 | 08:49 PM
2002 F350V10's Avatar
2002 F350V10
It would be easier to sell your 5.0 and buy what you need.
Old Dec 29, 2010 | 09:54 PM
bill11012's Avatar
bill11012
Modular motor junkie
A 5.4 can be had for a few hundred dollors from a junk yard.
Thats the best way to go.
Old Dec 29, 2010 | 10:23 PM
gearloose1's Avatar
gearloose1
No state in the union will permit you to put a motor that far back into a chassis designed and certified for a motor that recent.
Never pass a smog check... so you are restricted to using it where there are no checks at all --- even when you sell it.
