Extra GPR
Old Dec 29, 2010 | 11:22 AM
damons's Avatar
damons
Extra GPR
Anyone have a spare GPR for my E99, I'm suspecting is bad or going to be bad, I'd love to test a different one to make sure!!
Old Dec 29, 2010 | 11:24 AM
Waltdog's Avatar
Waltdog
of American machinists
I have a spare I can send you, its from a 2002 but should be OK? PM me your mailing addy and Ill mail it to you.
Old Dec 29, 2010 | 12:25 PM
woodnthings's Avatar
woodnthings
Testing of the GPR is pretty straight forward. If you turn the key on and you have power to the two large posts it is good. If you only have power to one of the posts, and you can hear it click on, the relay is shot.
You may have a worn contact if you hear it click and do not get power to the GP post. That is what was happening on this GPR.
Old Dec 29, 2010 | 01:03 PM
damons's Avatar
damons
I do hear it click, I am getting voltage on both posts. I had been trying to start my rig for 4 days, finally got it started after two attempts of jumping large posts for 30 seconds.
Old Dec 29, 2010 | 02:27 PM
Brother Les's Avatar
Brother Les
Why not buy one from NAPA?
# GPR109
around 30.00
Old Dec 29, 2010 | 03:10 PM
2cylguy's Avatar
2cylguy
Or a Stancor?
Old Dec 29, 2010 | 05:12 PM
damons's Avatar
damons
I will when I know for sure that is the problem.
Old Dec 30, 2010 | 11:39 AM
boone1965's Avatar
boone1965
I was going through a GPR each winter in my 99.5 PSd and upgraded to a stancor and its been great for the last three years! This forum is great when it comes to problem solving and replacement items for teh trucks! Actual experience with parts and problems beats teh dealer any day!
Old Dec 30, 2010 | 12:29 PM
damons's Avatar
damons
Is this the bottom or top?
Old Dec 30, 2010 | 05:26 PM
danskool's Avatar
danskool
Go Bills !
I Think you tested you GPR already? I was getting voltage on the gauge with my second one in a year napa relay.. But dropping extension across the big terminals made my motor fire right up. New stancor installed and never looked back. Check Ohms on your glow plugs?
You can also use your AIH heater relay to try. If the E99 has one.
Old Jan 8, 2011 | 04:20 PM
damons's Avatar
damons
Ok, so I replaced the GPR with the used replacement, but before I disco'd I tested one more time, hot volts were 12.54, other post after turning on key 10.45, after replacing with used one, 2nd post was 11.15v, should this be higher? Will the Stancor let more Volts through, maybe a battery deficientcy?
Old Jan 8, 2011 | 05:07 PM
damicofuel's Avatar
damicofuel
If glow plugs havent been replaced, I would consider that job! I am still on origional GPR but replaced glow plugs 2 years ago and starts great!
Old Jan 8, 2011 | 05:38 PM
damons's Avatar
damons
We checked them 2 months ago as I have had hard starts for over a year. They all where .8 ohms.
Old Jan 8, 2011 | 05:56 PM
cj45lc's Avatar
cj45lc
That sounds about right, as soon as the relay makes contact you have 8 glow plugs drawing current/volts so it will drop the volts.
