Speedometer Problem
Old Dec 29, 2010 | 11:05 AM
mr_ranger-79's Avatar
mr_ranger-79
Speedometer Problem
Hello all. I have a quickie question about the speedometer. When I first take off, whether the engine is hot or cold, the speedometer doesnt move until I hit approximately 25 mph. Then it works just fine. I have tested it on the freeway and it is perfectly accurate. The problem is ONLY when I first go to drive it, sometimes it doesnt start to work until I get around 30 mph. After that though, it works perfect even at lower speeds such as 10 or 15 mph. I am sure most people would say deal with it but I am curious what I should look at first, cable or the actual speedo gears? Any thoughts would be greatly appreciated. My truck is a 1979 F-250 XLT 4x4, 400 c.i., 4 speed manual. Thanks.
Old Dec 29, 2010 | 11:28 AM
seventysevenF150's Avatar
seventysevenF150
Is it jumpy at all? U might just need to lube the cable a bit. Could be binding at low speeds when it's cold.
Old Dec 29, 2010 | 11:36 AM
mr_ranger-79
It is a little jumpy, especially at first...but usually smooths out after a bit.
Old Dec 29, 2010 | 12:00 PM
seventysevenF150
I would lube the cable. I had a car that the speedo would jump violently till about 30mph. I took the dash cluster out and sprayed lube down the cable, drove a bit, a little more lube and then put the cluster back in (don't forget to hook the speedo back in) and within a few drives it was normal.
Old Dec 29, 2010 | 12:03 PM
mr_ranger-79
What did you use for lube? I had a prelude that had a "bouncing" speedo and the stuff everyone recommended I couldn't find. The only lube I have found at Autozone is made for brake cables, just not sure what to use for speedo cables.
Old Dec 29, 2010 | 12:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Inside the speedo cable's housing is a woven steel core. A replacement core kit can be bought from autoparts stores.
To lube the woven steel core, use a thin coating of White Lithium Grease.
Old Dec 30, 2010 | 02:34 PM
seventysevenF150
I just used Liquid wrench,. or WD-40
