Recommend next diesel?
Old Dec 28, 2010 | 11:52 PM
scrdanis's Avatar
scrdanis
I had an F-250 '04 Lariat Extneded cab with a 6.0L and loved it. I need to get another. Will stay with the diesel but any year and size recommendations? I know the F-250's reecently had poor fuel milage but understand they were corrected. Don't think I'll be able to afford a new one but when did the "GREEN" diesels come out? Just last year or the past couple years?
Old Dec 29, 2010 | 06:37 AM
AGE mechanic's Avatar
AGE mechanic
If you are going to stay with Ford and want to keep the price down, get a 06 or 07. Plan on doing the usual head gaskets, oil cooler, EGR cooler. You should factor that into the price right off the bat. Check oasis and have your scan gauge in your pocket when looking.
Old Dec 29, 2010 | 08:09 AM
gearloose1's Avatar
gearloose1
If the price is right, you can go for 2003.
e.g. a 2003 / 04 that is got tuners, empty degas, signs of coolant puke, etc.
I would buy it building in the price of a reman long block, new cooling system, etc.
$15,000 pays for a lot of fixes.
Old Dec 29, 2010 | 08:22 AM
texans's Avatar
texans
not sure what you mean . Diesel has always been green here in Tx.
Old Dec 29, 2010 | 05:23 PM
scrdanis's Avatar
scrdanis
I was reffereing to the fuel re-burner add to the engines. I think it was in 09 they came out and those that bought them saw greatly decreased fuel milage and weren't happy.
AGE- scan tool is good idea!.
Thanks for the info 06-07. Gotta wait for the final from the insurance to see what I will be able to afford. Probably next week.
Old Dec 29, 2010 | 05:39 PM
ljutic ss's Avatar
ljutic ss
In the 2008 MY the 6.4 was introduced with a DPF reburn system. This is what your thinking of, stick with the 6.0
Old Dec 29, 2010 | 05:45 PM
69cj's Avatar
69cj
I agree with ljutic 100%. The 6.0 is simpler and cheaper to work on than the 6.4 and the 6.4 is just starting to show some ugly heads.
Old Dec 29, 2010 | 05:47 PM
gearloose1's Avatar
gearloose1
No matter how you cut it, there were somewhere like 1 million 6.0s made.. that is a lot of cores, a lot of cheap parts out there.
Not so for the 6.4.
Old Dec 29, 2010 | 06:00 PM
69cj's Avatar
69cj
Not so for the 6.4.
I think the correct term is less expensive. There is nothing cheap on any of the new diesels.
Old Dec 29, 2010 | 09:14 PM
scrdanis's Avatar
scrdanis
The re-burn system is exactly what I was refering to. I did hear that the new ones with the re-burn system are better but they are too far out of my price range.
Old Dec 29, 2010 | 09:44 PM
ljutic ss's Avatar
ljutic ss
The re-burn system is exactly what I was referring to. I did hear that the new ones with the re-burn system are better but they are too far out of my price range.
Ford DPF system was only 2008-2010 the 2011 does not use DPF it uses a urea injection which has heaters in the urea tank to keep it from freezing which is around 10 deg. f. So besides worrying about quality diesel fuel you have something else to tend to once the urea tank gets low. I think it's time for the EPA be dissolved.
Old Dec 29, 2010 | 10:18 PM
scrdanis's Avatar
scrdanis
So pre-2008, F-250 or 350, moderate miles, taken care of and in my price range? Right. Could happen but will take some looking.
Old Dec 29, 2010 | 10:23 PM
High Binder's Avatar
High Binder
I've got a new 6.7 and it's been way more of a turd than my 6.0 with 160,000.
Old Dec 29, 2010 | 10:25 PM
gearloose1's Avatar
gearloose1
The 2011 have both a DOC (Diesel Oxidation Catalyst) and a DPF.
Old Dec 29, 2010 | 10:29 PM
ljutic ss's Avatar
ljutic ss
Is your 6.7 like a Mercedes blue tech where you only get 20 starts when your out of urea, and the engine will not start until the urea is refilled?
