Sponsored by: Auxito
Check engine code is Po353
Old Dec 28, 2010 | 08:48 PM
svenska57's Avatar
svenska57
Question Check engine code is Po353
My 97 Ford F-150 extra cab 4.6 l V-8 4x4 was in an accident where I blew my brake line and ran the curb which damaged the r/f undercarriage area (axle,tie rod,upper arm assembly etc.) I had truck fixed last week. My battery needed replacement so I bought a new one today and put it in. My check engine light is now on indicating code-PO353. This is ignition coil primary circuit number 3. I replaced both coils, wires, and plugs last summer. I did a visual inspection on the coils and wires and they seem all right. Neither coil shows any sign of it being burned out. Any suggestions? Could I have knocked something lose when I ran the curb in earlier accident?
Old Dec 29, 2010 | 12:46 AM
Bluegrass 7's Avatar
Bluegrass 7
The computer sees the coil for that cylinder as open.
Check out the plugup connection and harness.
Just 'looking' at it won't tell you if anything is open.
The computer has to apply a ground to the coil when it comes up in the fire order so the computer could even be faulty.
Get copy of the Haynes manuel to see the circuts and make tests.
Good luck.
Old Dec 29, 2010 | 07:14 AM
projectSHO89's Avatar
projectSHO89
Unrelated to the MIL, but if your brake line failed due to corrosion of the line, please make a report on NHTSA's website. I suspect that this is a largely unrecognized problem with these trucks.
https://www-odi.nhtsa.dot.gov/ivoq/
Old Dec 29, 2010 | 08:10 PM
svenska57's Avatar
svenska57
Question New Question & Update on code#PO353 Problem
I looked at my 97 f-150 again today because I was getting the PO353 code. I Checked all plugs and coil wires and made sure they were fastened properly. The driverside two top coils # 4 and # 7 were not making any spark. When I replaced this coil earlier in the year I snapped the original bolt that fastened the coil to the ground bracket. Looking at the coil from the top the #4 and #7 coils are clean and don't show any burned out signs. Could it be possible that I need to take off coil and clean the bracket and coil bottom due to a bad ground?
Old Dec 30, 2010 | 07:50 PM
svenska57's Avatar
svenska57
re: code PO353
Checked the wires again today and noticed a broken wire going into the plug in on the d/s coil. Spliced together and taped and truck working smoothly again! Thanks for the help!
ms_michelle
Nov 26, 2016 08:46 PM
02 F150 54 v8
1997 - 2003 F150
Jun 21, 2013 11:50 PM
robin1t2002
1997 - 2003 F150
Apr 23, 2012 10:29 AM
JWA
Modular V8 (4.6L, 5.4L)
Mar 12, 2012 06:50 AM
05turbo
2004 - 2008 F150
Jul 30, 2011 11:13 AM
