Stalling, that wouldn't ignite
Old Dec 28, 2010 | 06:40 PM
justindbell's Avatar
justindbell
I was driving the work the other day, when my truck suddenly shut off and I started gliding with no power breaks or steering. At least I went to a good spot, although once I was at a stand still it would not turn over, and ignite. Once I towed it home, and got it to the bottom part of my property, it started right up with out any problems. I have a 2000 ford f250 7.3. I have never had any problems with it and was wondering if that sounded like something that would have been Camshaft Position Sensor. I thought for sure it did, so I took it to ford. And so did the head mechanic, so I ended up replacing it plus the sensor for the cruise control. I just kind of wanted to pick a few people’s knowledge to see if they thought for sure that is what it was. I just don’t want to have that ever happen again, and have confidence in my truck yet again.
Thank you!
Old Dec 28, 2010 | 07:00 PM
carltonwebb's Avatar
carltonwebb
Sounds like it could be the sensor. Did they replace the sensors under the recall? It would not be a bad idea to keep a spare CPS in the glove box should it do it again. Easy to change and beats waiting on a tow truck anyday.
Old Dec 29, 2010 | 04:49 PM
justindbell
Thank you, and yes they did replace it with a gray one.
Old Dec 29, 2010 | 04:56 PM
dn29626's Avatar
dn29626
Now that you have plenty of posts, feel free to add a signature about your truck.
A failing CPS will cause the problem you experienced. A spare is highly recommended.
evan96F250
Sep 15, 2010 01:01 AM
Bob97F350
19
Apr 13, 2009 05:10 AM
musthunt
Jan 12, 2007 09:53 PM
alchymist
Nov 15, 2006 05:17 PM
