Big Problem?, Little Problem?
Old Jan 12, 2007 | 12:44 PM
musthunt's Avatar
musthunt
Unhappy Big Problem?, Little Problem?
Ok, When I went to change my serpentine belt.
I went to open the drain on the bottom of the radiator, and lo and behold it come off in my hand.
Thank God it wasnt leaking any coolant.
Now, is this a serviceable item?, or does it require a radiator change.
I plan on switching to ELC soon, so if I have to drill it out it's not a huge issue.
Old Jan 12, 2007 | 01:19 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Are you referring to the drain with the white plastic hexnut on the bottom? Which part came apart, the hexnut?
Old Jan 12, 2007 | 05:17 PM
musthunt's Avatar
musthunt
Yep, the little white hex nut looking doodad, not to be confused with the zoodad.
Came off just using manual torque, no tools required.
Old Jan 12, 2007 | 05:36 PM
Tenn01PSD350
I would think you could replace that. Have you looked for the doohickey on Milennium Ford's site?
Old Jan 12, 2007 | 06:30 PM
jtharvey's Avatar
jtharvey
Mine comes all the way out too. When you removed it, did the coolant drain out ok? I don't think they have to be very tight to keep coolant from flowing out.
Old Jan 12, 2007 | 09:50 PM
musthunt's Avatar
musthunt
Didn't come out, broke off before it could unseat / unscrew.
Old Jan 12, 2007 | 09:53 PM
musthunt's Avatar
musthunt
No, I'm at work until the 17th. I have one of the Ford service CD's but havent had time to look at it either.
I was hoping maybe someone else had this problem already.
HD74
47
Jun 4, 2022 10:41 AM
jvencius
23
Feb 14, 2013 10:57 PM
evan96F250
Sep 15, 2010 01:01 AM
Bob97F350
19
Apr 13, 2009 05:10 AM
TrekChick
20
May 22, 2006 07:16 PM
