engine swap problem
Old Dec 28, 2010 | 02:18 PM
deere55's Avatar
deere55
engine swap problem
I am in the process of swapping my 1991 f350 7.3 idi with a 1993 e350 7.3 idi. I've got the new one in and almost done, but I've run into a problem. The front end of the engine is pointing too far upwards. It's like the engine and tranny are tilted backwards. I thought I put everything in right, does anyone know why it is doing this?
Old Dec 28, 2010 | 03:51 PM
mabc926's Avatar
mabc926
Did you put the engine and trans in connected to each other?
Only thing I can think of is check your engine and trans mounts.
The engine does tilt back a LITTLE but not that much.
Old Dec 28, 2010 | 04:06 PM
deere55's Avatar
deere55
Yes, I pulled it all out as one unit, and put it back that way. I just put the radiator and core support back in, and that's when I noticed the problem. If a have the core support mounted high enough where the fan cover doesnt hit the fan, then the radiator cap is about 3 inches higher then the fenders, and I know that that isn't right because the hood won't be able to close...
The engine mounts have to be fine, I used the ones from my truck, so they're the same. I'm wondering if somthing is wrong on the back end of the transmission. I had to take that crossmember piece off and maybe I put it back wrong, I had it out of there for a couple of months, I might have forgotten how it's supposed to be ...
Does anyone have a picture of how that is supposed to be back there? Mine is a 4x4 zf5.
Old Dec 28, 2010 | 07:53 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Did you change the exhaust manifolds and oil cooler?
F series and E series are different.
Old Dec 29, 2010 | 10:00 AM
38Chevy454's Avatar
38Chevy454
This sounds like an area to check. Since the engine mounts are the same, and the fornt of the engine is higher, logic says the rear trans mount is low.
Old Dec 29, 2010 | 04:43 PM
deere55's Avatar
deere55
It turns out I may have been wrong all along. I think it is the way it is supposed to be. It just didn't look right to me at first. I had kind of forgotten, its been apart for 4 months.
Old Dec 30, 2010 | 10:09 AM
kenpobuck's Avatar
kenpobuck
I looked at mine and the rad and cap sit way above the core support. Looks like the hood should hit but it don't. Before doing anything else, put the hood on and see if it clears.
jamwalker1
Engine Swaps
Nov 29, 2014 11:50 AM
rougeriver
Jul 15, 2014 12:06 PM
4benjamin
Oct 16, 2013 08:35 AM
Black Cowboy
Feb 11, 2008 06:04 PM
d_stange
Jul 7, 2006 12:31 PM
