Help pulling ABS codes?
Old Dec 27, 2010 | 09:45 PM
Beastlyforddude's Avatar
Beastlyforddude
My abs light is on. When it is on i have no torque converter lock up.
how do you pull abs codes???
thanks.
Old Dec 28, 2010 | 12:09 PM
Beastlyforddude
i have reason to believe its the proportioning valve???
does anybody know if the proportioning valve sends a signal to the pcm to disengage torque converter lockup?????
Old Dec 28, 2010 | 12:17 PM
subford's Avatar
subford
No it does not.
The RABS system has no signals going to the PCM Computer or the Transmission.
Sounds like you have a VSS (rear sensor & wiring), PSOM or RABS problem.
Old Dec 28, 2010 | 01:39 PM
Lazy K's Avatar
Lazy K
Only thing I can think of to cause both things is the brake lights stuck on (possibly brake light switch sticking).
Old Dec 28, 2010 | 02:33 PM
Beastlyforddude
thanks for the advice.
How would it be a PSOM problem?
i like the thought but idk how that would cause no torque converter lock up....
vss is new.
It isnt a brake switch, it works properly. all wiring is fine.
Old Dec 28, 2010 | 02:50 PM
Lazy K's Avatar
Lazy K
Well, the RABS computer will turn the ABS light on if it doesn`t receive a brake light on and off signal and the torque converter lockup is disabled when the PCM receives a signal that the brake lights are on.
However maybe you have two unrelated faults, one in the RABS and in the lockup circuit.
Maybe try checking for any trans related trouble codes (use the self test if you don`t have a code reader).
Old Dec 28, 2010 | 03:27 PM
subford's Avatar
subford
If the PSOM is bad it may load the VSS circuit and cause the RABS module to turn on the Yellow lamp.
Also if the PSOM is bad it would not send the speed information to the PCM Computer and then the PCM would not lock up the TC.
It would also shift hard and the speed control would not work.
Old Dec 28, 2010 | 07:10 PM
Beastlyforddude
That is a good amount of info I did not know about the PSOM, thank you very much!
Idk if that would cause the problem to come and go though...
I pulled ABS codes and got "11"
So what does ABS code 11 mean??
Old Dec 28, 2010 | 07:21 PM
danr1's Avatar
danr1
"Brake light switch always closed" Service circuit 511 Open/short
Service brake switch.
Circuit 511 = light green wire between the brake light switch and the rabs module. According to my diagram it tee's off down stream of the stop lamps, so based on that this statement
It isnt a brake switch, it works properly would be a possible and suffer the condition you describe. IE brake light switch and lights work, but TCC won't lockup.
Old Jan 2, 2011 | 10:44 AM
Beastlyforddude
i'll trace the wire back to the pcm then, but in the meantime i think its the psom acting up....
Old Jan 2, 2011 | 11:36 AM
subford's Avatar
subford
Wire 511 has nothing to do with the PCM.
Old Feb 16, 2011 | 01:54 PM
Beastlyforddude
SOLUTION!
i have l.e.d. tailights on my flatbed. usually you need a resistor when installing leds so that the abs module and computer can detect that your tailights are functioning. improper functioning of tailights will DISENGAGE tc lock.
since i dont run resistors, my computer relies on the third brake light to create the resistence needed for it to detect that my tailights are functioning. turns out i had a bad connnection to my third brake light.
i fixed that and now i have tc lock up again
esbrian
Jul 6, 2017 06:07 PM
mfp4073
1983 - 2012 Ranger & B-Series
Feb 25, 2016 05:10 PM
Diesel_Brad
Oct 7, 2012 08:59 AM
boot2
Jun 26, 2012 05:33 PM
Miketnf150
1978 - 1996 Big Bronco
Aug 21, 2002 12:57 PM
