wheel dilema
Old Dec 27, 2010 | 05:02 PM
cherokeexj32's Avatar
cherokeexj32
wheel dilema
I have a stock 03 Expy with the FX4 package that came with the chrome rims and 265/790/18 rims.
About 2 months ago I bought a set of F150 FX4 stock rims off an 05 F150 which are 18".
Discount Tire is concerned on the backspacing difference of I think 4mm. Also looks like in order to keep the relatively stock size tire of 31.6" in the 18, I would have to to go a 265/65/18 and of course the types of tires goes down with that size.
Has anyone done this conversion of wheels or can offer any advise if I should still stick with the F150 rims and go with the 265/65/18 tires?
Any info you guys can give me would be a big help!
Old Dec 28, 2010 | 09:30 AM
broncoholic's Avatar
broncoholic
I can't offer much advise on the offset, except 4mm doesn't seem like it would affect much.
For tires, you could go with a 275/65R18. It's only 32.0 or 32.1, depending on tire make. I run a 285/70R17 on my 03, which is 32.8, so you'd have no issues with 275/65R18. Before I get my next set of tires, I was actually hoping to find a cheap set of factory 18's cause I think a 275/70R18 will fit, which is 33.2.
Old Dec 28, 2010 | 10:07 AM
38Chevy454's Avatar
38Chevy454
4 mm is less than 3/16 of an inch! Tire shop needs to find something worth worrying about. Only problem a slightly taller tire will do is make your speedo off a small amount. But even 1-inch difference on a 31 inch tire is about 3%. Again, not worth worrying about.
Old Dec 28, 2010 | 10:09 AM
cherokeexj32
I just realized I messed up my original post. I should have said my truck came stock with 265/70/17s on it.
I am going to pull the Expy into the garage today and see how the FX4 rim looks on the front end and do some steering test.
In tire comparisons (I want to keep the same height as stock so I can keep my current spare) if I was to keep the 18" FX4 rims I could go with a 265/65/18 and according to the conversion sites, it will be the same size.
If all looks good I am going to hit Discount Tire again today and see what tires may work with that size. Problem is with this size, the choices goes down. I have one other place in the area that sells cheaper tires but warranties them well.
Old Dec 28, 2010 | 10:29 AM
alwaysfords41's Avatar
alwaysfords41
Make sure you select the 2WD option on the dash, running different sized tires will force the computer to think wheels are slipping and 4WD will engage if you are in Auto.
Old Dec 28, 2010 | 11:46 AM
cherokeexj32
I just went outside and test fit the FX4 rims. When mounted the hub comes in about 40% of the way into the rim center. Is that going to be enough contact area for this rim to be ok?
donniezyea
Jul 3, 2013 12:08 PM
zcpro
Apr 13, 2011 08:45 PM
NASTYHABIT2
2004 - 2008 F150
Dec 31, 2009 07:13 PM
YOMAN
2004 - 2008 F150
Jul 13, 2007 07:23 PM
timmyjimmy5150
1997 - 2003 F150
Feb 21, 2006 06:34 PM
