here we go again
Old Dec 26, 2010 | 07:52 PM
levi300strt6's Avatar
levi300strt6
here we go again
alright so i dont know what the **** to do lol, my 1978 f250 custom is just weird, i need to what to do to fix it, this is what happens when i put the key in....nothing, i have no headlights and no electrical, theres no turn over and no crank, not even a sound, and it all started when i got a new alternator for it. i put it in and hooked it up and then nothin the next day. i dont even know were to begin. any suggestions?
Old Dec 26, 2010 | 07:54 PM
justforkicks's Avatar
justforkicks
well, the only thing i can think of is a short. try jumping it?
Old Dec 26, 2010 | 08:44 PM
levi300strt6
ya know thats what my pops was sayin, but the old man i bought the truck off of was doin all these crazy things with the wiring, like its all jumbled around and ****, all taped up so i dont know were the hell im going ya know, but thats my thoughts too, i just need a wiring diagram or something so i can know whats going on, you wouldnt by any chance know were i can find one do ya?
Old Dec 26, 2010 | 08:48 PM
justforkicks
well, where i would start is at the solenoid. i've had wires cook at the solenoid and i had no power. took me a couple days before i realized it and fixed everything. from there, i'd work my way to the ignition or the alty
sorry, i don't happen to have a wiring diagram, but the wiring is somewhat straightforward. the only really complicated part of the wiring is the ignition module, and i'm talking about the inside, not outside
Old Dec 26, 2010 | 11:51 PM
F-250 restorer's Avatar
F-250 restorer
First off, I would take a long, hard look at the alt. wiring. That is where it started. Check your grounds, ALL OF THEM; take them off and make sure you have clean metal beneath them. Then, I'd take the new alt. to the auto p. store and have them test it. If it is charging, you need to charge your battery (clean the posts) and re-install. Get it started and charging, then you can redo the wiring to original.
Old Dec 27, 2010 | 12:02 AM
Kalve's Avatar
Kalve
check the solenoid & voltage regulator & have Advance an them check the alternator & starter an check the battery & battery cables. Maybe it drained the battery also. An check all connections also what bout the ignition switch itself going out?
Old Dec 27, 2010 | 07:14 AM
co425's Avatar
co425
Start with the 16 ga fuseable link from the solenoid to the fat 12 ga black with yellow stripe wire. It will lead to a 3 hole plug with a red and yellow wire. The red and yellow are your ammeter gauge or charge warning light wires. The fat black with yellow stripe is your cab main power wire. Without power to the black/yellow wire your truck is dead. 10 bucks says you have a shorted or worn out and failed fuseable link. You can get a new fuseable link wire at most auto stores.
Old Jan 5, 2011 | 05:02 AM
dulockdrumheller's Avatar
dulockdrumheller
You check neg cable to block?
Old Jan 5, 2011 | 09:02 AM
fmc400's Avatar
fmc400
MSEE
Sounds like a classic case of a blown fusible link. You most likely blew one while changing out the alternator; they're right there in the same area.
SWAT KHAN
1997 - 2003 F150
Oct 8, 2012 09:16 PM
octaneforce
Jul 11, 2009 06:40 AM
jasonjason
Feb 15, 2008 09:41 PM
Mat Dope
Offroad & 4x4
36
Nov 3, 2007 06:33 PM
southernboy
Feb 17, 2003 05:05 PM
