Engine Thermostat/Temperature
Old Dec 26, 2010 | 06:04 PM
02X72's Avatar
02X72
I just made the trip up north with the truck for the first time and am having an issue with the heater working. First of all its an aftermarket heater in the truck. The thing would not get very hot so I started poking around with under the hood and noticed that the motor and hoses were not getting very hot. I could place my hand on the motor and hoses and not get burnt, which seems like it is too cool to me even though it was 10-15* outside. Sounds to me like a thermostat issue if the truck is not getting up to temp. I plan to install an aftermarket temp gauge, but thought I'd get your guy's thoughts first
Old Dec 26, 2010 | 06:21 PM
charleswood6969's Avatar
charleswood6969
Sounds like you have a t-stat stuck open. Make sure you get the proper one from either Ford or IH dealership. DON'T GO to NAPA or some other parts store. They, as I understand it, require a special one.
Old Dec 27, 2010 | 10:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The corrct thermostat is 195 degrees.
And the heater should be able to run you out of the cab at 10 or 15 outside.
Old Dec 28, 2010 | 12:13 AM
Country_boy_2007's Avatar
Country_boy_2007
try a peice of cardbord infront of the rad. i was haveing troubles after i replaced my rad and Tstat. the new rad cooled so much better cause it wasnt full of scale like the olf one, i had to truow some cardbord in front and now it warms up to temp.
Old Dec 28, 2010 | 02:59 AM
Aune163rd's Avatar
Aune163rd
O'Reilly sells OEM thermostats, they are the only people i will go to other than the dealership or IH/NS. O'reilly had my starter for my 6.9, new gp, injectors and all the like. At any rate. They sell all OEM stuff. I would invest in a 195 thermostat. That will warm you up and out of the truck when working right.
Old Dec 28, 2010 | 08:00 AM
1994F2507.3L's Avatar
1994F2507.3L
MOTORCRAFT (FORD) THERMOSTATS:
Thermostats - 1994 Ford F-250 | O'Reilly Auto Parts
sold by oreilly you have to call in for price on most of there motorcraft products.
Old Dec 28, 2010 | 09:50 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by PLC7.3
Originally the IDI diesel came with a 4 row HD brass rad....... I don't understand why they are selling aluminums as replacement.....
Diesel engine coolant temperature at the top of the radiator where hose attaches after high rpm or under load condition for 20 minutes should be (195-237*F) 91-114*C nice time to have a temperature reading point and shoot tool.
Did the PO replace the thermostat too, overheating could mean the wrong one installed....... need a Ford or IH Tstat only.
CAUTION:
The specified/required thermostat does not contain an internal bypass, since the bypass is located in the cylinder block. Whenever the thermostat is replaced, it is mandatory that only Motorcraft E5TZ-8575-C or Navistar 1807974C94 thermostat be installed.
Motorcraft E5TZ-8575-C = 192* fully open = 212* (best for fuel economy and performance.)
Navistar 1807974C94 = 180* fully open = 200* (best for running cooler should you find the need for your application.)
in case its time for a couple radiator hoses,cap and flush:
http://www.oilburners.net/articles/cavitationartic.html
Old Dec 28, 2010 | 08:37 PM
Dave Sponaugle
I usually plow with my defrost on high and the drivers side window down at temps down to 10 degrees.
That keeps my windows from fogging up from all the snow I track in the cab as it melts.
Old Dec 28, 2010 | 08:43 PM
02X72's Avatar
02X72
I have no idea if the PO did anything with the t-stat. I ordered a new one from Ford today and hopefully will be able to get it in there tomorrow. The truck defiantly was not getting anywhere near 195*, like I said I could hold my hand on the motor and hoses and it was pretty cool. Im gonna add a cover for the front grill as well, did that for my dads powerstroke and it made a big difference
Old Dec 28, 2010 | 08:57 PM
Dave Sponaugle
If you are not working the engine, a diesel does not make much heat.
So the upper radiator hose may not be that warm.
The lower radiator hose will be much cooler, even in the summer.
The heater hoses however should be rather warm after a mile or so driving down the highway.
Old Dec 28, 2010 | 11:56 PM
02X72's Avatar
02X72
Even those were not getting all that warm.
Old Dec 29, 2010 | 12:16 AM
Dave Sponaugle
Sounds like a thermostat problem to me.
Stuck open.
Old Dec 29, 2010 | 01:55 AM
ihateminimumwage's Avatar
ihateminimumwage
I installed a Kragen T-Stat after doing my head gaskets to get my truck back on the road even after reading that all the aftermarket stuff was garbage. There was a waste of time and money swapping out for a overpriced dealership one if this actually is the case...
Old Dec 29, 2010 | 07:54 AM
1994F2507.3L
orielly selling OEM stuff meaning you can get MOTORCRAFT at oreilly
Old Dec 29, 2010 | 01:15 PM
ihateminimumwage
Ahh, that's right. OEM vs the cheap stuff. Glad to know the extra work wasn't for nothing...
abe
Feb 17, 2016 03:02 PM
lcgeek
Dec 2, 2015 12:05 AM
Rusty_S
28
Nov 29, 2015 07:28 PM
granny_rocket
Jan 20, 2015 06:48 AM
Coneynew
16
Jan 8, 2007 12:09 AM
