2011 F250 vs. F350
2011 F250 vs. F350
As always, I continue to search/research possible trucks, what can I say, I like trucks...
Went to a dealer today and looked at the F250 and F350, Crew Cab/Short Box configurations. I don't really need a F350 but I much prefer its look when compared to the F250. I know, they're the same body and generally look the same but the stance is different. The F350's back end is like 2.5 inches higher than the F250. Looking at the leaf spring suspension, they look identical to me (the F350 has a helper spring but it doesn't change anything when unloaded). Both trucks had 20 inch wheels, same tires and the FX4 option.
So, where is he going with this you will ask? Well... why is th F350 higher? I tried to search for suspension replacement online to see if there was a difference and can't seem to see one, yet the trucks just don't sit the same way. To all of you experts, why the difference?
Ben
Ben
350's have hydroboost brakes
Different spring setup
Different Axles, see below (scroll down about 1/3 way to see F250, F350 and F450 axles)
https://www.ford-trucks.com/forums/9...nch-event.html
need longer u-bolts and new nuts with taller blocks thats the money I spoke of hydraboost is on trucks 10.000 gvw or oil buners with no vacume
I'm not saying you are wrong. I just know that the past models of SRW F-250/350 trucks are identical besides a block in the rear and badges. They may have been showing the Dually axle which would be rated higher thus bigger, same with the Dually spring set up. Just as Ford does with a lot of advertising is show the best components of each model and the DRW version of the 350 would have stronger, larger, and more appealing parts. Again not saying you are wrong but I have read in the SuperDuty Tech Folder about the differences between the SRW trucks.....and there is none, according directly from Ford. But things may have changed for 2011. Interesting to see if this is the case or not.
The diesel engined trucks get hydroboost. Gas engined trucks have vacuum assist.
Spring choice is dependent on GVRW, not model. You can see the same springs in an F-250 or an F-350 SRW.
No, the F-250 and F-350 SRW both have the Visteon (Sterling) 10.5 rear axle and the DANA-60 front axle. The F-350 DRW gets a different axle,
