State Inspection Sticker
Old Dec 26, 2010 | 03:45 PM
carino's Avatar
carino
I wonder if anyone has the same problem passing the State Inspection because of exhaust fumes. Every year I have to pay a garage to fix the problem. I have done this for the past three years. Any suggestions or feedback on why my truck fails every inspection and I have to pay an average of 135 dollars to fix the exhaust problem. Thank you for your continued help.
Old Dec 26, 2010 | 04:21 PM
TexasGuy001's Avatar
TexasGuy001
What do you mean by fumes? Is it exhaust leaks, or is it failing sniffer test?
Old Dec 26, 2010 | 09:17 PM
carino's Avatar
carino
It keeps failing the "sniffer test". They have replaced converter and other items but every year it fails this test. What is going on?
Old Dec 26, 2010 | 11:17 PM
drjoe171's Avatar
drjoe171
What engine, year and what state info will help to figure it out.
Old Dec 26, 2010 | 11:28 PM
bren_tx's Avatar
bren_tx
Which gas are you failing with? I always do the seafoam treatment (in the intake and the gas) before i take the test, and i always pass with flying colors.
Old Dec 27, 2010 | 10:40 AM
carino's Avatar
carino
1991 5.OL V8 OHV 16V. I live in Texas. Bren_tx, I just fill up with regular fuel. Please explain what the "seafood treatment" is and what you mean when you say "in the intake and the gas" As you can tell, I do not know anything about most of these things but your patient and understanding is appreciated. Thanks
Old Dec 27, 2010 | 10:57 AM
mikeismadness's Avatar
mikeismadness
its not sea food its called seafoam. i add it to my gas its a treatment for gas and oil...its not too pricey but next test try filling your truck with mid-grade fuel and add seafoam...im guessing you should pass
Old Dec 27, 2010 | 11:23 AM
carino's Avatar
carino
I understand and will add this treatment next time. Thank you very much.
Old Dec 27, 2010 | 11:43 AM
mikeismadness
yup no problem youll notice your truck running a bit better too
Old Dec 27, 2010 | 12:02 PM
bren_tx's Avatar
bren_tx
Seafood? Sorry I get I shouldn't post that late at night any more haha. Don't know what happened there
Old Dec 27, 2010 | 12:44 PM
planehunter's Avatar
planehunter
You should always have an oil change done before you go in for a smog test, and make sure it's up to normal running temps.
Old Dec 27, 2010 | 12:59 PM
carino's Avatar
carino
I had forgotten this. About three years ago a mechanic said for me to run the truck for at least 30 min prior to going in for an inspection. The truck sits for weeks and is only used when helping friends or when I buy a large item. Guess when a vehicle is not driven and only sits, a lot of things can happen. Thanks.
Old Dec 27, 2010 | 03:14 PM
TexasGuy001
Yeah run some Seafoam or CRC G2P in it on the tank full before its time to do the sniffer. It will clean stuff up some and help. I don't think you want to run it in the tank during sniffer though. Definitely make sure its warmed up really good. Drive it around for a while and drive it a little hard that should help. I always change my oil before going in too.
Old Dec 27, 2010 | 03:31 PM
mikeismadness
also just make sure your plugs and wires look good...older plugs good make you fail a sniffer test
Old Dec 27, 2010 | 03:33 PM
TexasGuy001
Good point.
