p132b code?
Old Dec 26, 2010 | 02:01 PM
KJG20036.0's Avatar
KJG20036.0
p132b code?
As I understand it, the early 6.0's have had problems with turbos sticking and causing a p132b code. It only sticks when cold, runs fine with a good warm up. My father in law came up with an idea, has anyone developed a lubricant that can be sprayed into the intake that can go through the motor without any problems? Something to lubricate the Variable Geometry Turbo to help the veins move a bit easier? Otherwise I think I am going to pull it and give it a good once over. Any other suggestions? Thanks again everyone!
Old Dec 26, 2010 | 02:11 PM
powerstroke72's Avatar
powerstroke72
Moved to 6.0L Powerstroke Diesel forum.
Old Dec 26, 2010 | 02:21 PM
gearloose1's Avatar
gearloose1
There is no lube that I know of that have been tried.
Though it is an intriguing idea ---- with the proviso that the temperatures in there are right up there, limiting the kind of oils you can use.
What I found is that the issue is rust, and if you let the turbo sit or not get "worked" it builds fast.
On the newer turbos, there is a coating on it that limits the problem.
stitch89
Dec 19, 2015 09:18 AM
bkeese
Dec 1, 2014 08:31 PM
bkeese
Dec 1, 2014 05:04 PM
F250Wheels
May 1, 2008 06:21 PM
E Hall
Oct 20, 2006 03:58 PM
